Leaking Coolant Help!!!
I drove 2-3 miles uphill until I reached my destination. I come out and see coolant leaking on the ground. Pop the hood and i see the coolant reservoir tank overflowing. Turned off the car for a couple minutes. Started it again and it sucked all the juice out of the reservoir tank. Anyone have any ideas what the problem is?
it is definately one of these 4:
1. rad cap failed
2. t-stat stuck closed
3. rad plugged
4. head gasket
most likely 1 or 2 because if it is 3, you're screwed, if it is 4 you might want to lube up and bend over.
1. rad cap failed
3. rad plugged
4. head gasket
The temp gauge was at normal level and the only leak I saw was from the reservoir. These past days ive been driving normal conditions and everything seems fine. I hope my car is not about to die. Just passed the 191k mark.
IBankMouse
06-13-2020 12:53 PM
