Jumpy Gas Pedal
Old Feb 10, 2010 | 02:23 PM
Craig92117's Avatar
7th Gear
Jumpy Gas Pedal
My '01 CL Base car has a very sensitive gas Pedal. When I go from a stop, It is very hard to prevent a lurching quick start. I own a TLs and the gas pedal is very smooth from a start. It is like a geometry issue with the gas cable? Mounts are fine, car has only 42k. What can be done?
Old Feb 10, 2010 | 02:37 PM
pits200's Avatar
Is it hard to push or does it actually feel like its stuck on the initial push?
2 possible things I can think of.
1.) The throttle cable adjustment nut isn't right
2.) The throttle body plate is sticking
Old Feb 10, 2010 | 02:50 PM
Craig92117's Avatar
7th Gear
It is hard on the initial push. I had the TLs with a sticking Throttle plate after the tranny replacement, but this does not feel like a sticking throttle plate.
Old Feb 10, 2010 | 09:59 PM
aznboi2424's Avatar
push the pedal with the engine off and see if you can feel anything wrong. If its sticky, too tight or too loose.
SidhuSaaB
May 30, 2020 12:40 AM
knight rider
Mar 4, 2016 08:59 AM
JDM96specCTR
Oct 17, 2015 01:06 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
San Yasin
Sep 29, 2015 10:52 AM
