J35a8
Old 06-11-2017, 10:01 PM
9th Gear
Anthony Clark's Avatar
J35a8
I have been working on pulling my transmission on my 01 cl-s (j32a2) I didn't want to rebuild it nor did I want to attempt a 6 speed swap myself. I heard about doing a 3.5 swap and heard that everything was pretty munch a direct swap. Also heard that I'd probably want to use my heads from my j32a2. Well I found a j35 that I thought would work with transmission for cheap. Turns out it's a j35a8 off of an 05 rl. Also from what I'm reading an 05-08 TL- s. Is this swap still possible. If so what am I gonna have to replace. Also what would be my easiest solution and step up if this won't work. And yes I did already by and receive the j35a8
Old 06-11-2017, 11:38 PM
thisaznboi88's Avatar
pull the j32a2 heads and see if it matches the coolant and oil ports on the j35a8. As you can tell the j32a2 has individual exhaust port while the j35a8 head single exhaust port. Also the bell housing for the transmission is different on the j35a8 vs your j32a2. It would have been easier if you bought a j35a3 mdx or j35a4 pilot.
good luck
Old 06-11-2017, 11:43 PM
9th Gear
So even though this j35a8 came with the transmission it won't work?
Old 06-11-2017, 11:44 PM
still have a problem with the cylinder head. mono port vs multiport, and crank and camshaft sensor are different.
andy running a j32a2 head on a j35a8, but then again we have hondata to tweak a few of the settings.
Old 06-11-2017, 11:46 PM
9th Gear
So would I be better off selling it?
Old 06-11-2017, 11:48 PM
if you want plug and play. J35a3 mdx 2000-2002 Acura MDX would be your best option if you want to do j32a2 heads on it. no piston to valve clearance issues
Old 06-11-2017, 11:49 PM
9th Gear
That's what I want. Is there transmission issues with that mix?
Old 06-11-2017, 11:50 PM
9th Gear
MDX not mix
Old 06-11-2017, 11:55 PM
i just told you plug and play. go on v6performance and look it up. it has been done before. not reinventing the wheels here. its tried and true
Old 06-11-2017, 11:57 PM
9th Gear
Thank you I appreciate the input. I'm so frazzled over this I just haven't been able to concentrate.
Old 06-12-2017, 12:40 AM
yup no problem. too many variation so just make sure you got the right one.
Old 06-12-2017, 10:01 AM
Derek
SykVSyx's Avatar
OP, I did the J35a3 setup with the 05/06 Oddy tranny in my 6th Gen Accord.
You will need the 03 TL Type S ECU(03 CL Type S 6spd ECU if you are going that route).
You can find a parts list on v6performance, I also have a detailed list on 6thGenAccord.com under the same S/N.
Old 06-15-2017, 12:02 PM
Adam Kovach's Avatar
i can vouch for this!!! my current setup.
