j32a2 rings
Old Dec 5, 2010 | 10:18 PM
malvothegreat's Avatar
j32a2 rings
Ok fellas I was spraying and lost alot of power and the car was smoking a little bit on the back side of the motor. The car is skipping on the middle cylinder on the back but the car is not smoking out the tail pipe but if I take the oil cap off compression is coming out of it really bad. so do yall think its rings or what?
Old Dec 6, 2010 | 01:12 PM
NSXNEXT's Avatar
Do a compression test on all cylinders.
Old Dec 6, 2010 | 01:18 PM
phee's Avatar
I got the Shifts
yes. and if you have low comp on a cylinder pour some oil in there and re crank it, if the compression rises it's a bad ring. if the comp stays low you burned a valve.
what shot were u running? wet? dry? brand?
Old Dec 6, 2010 | 08:16 PM
its wet and nitrous works
Old Dec 6, 2010 | 10:36 PM
civicdrivr's Avatar
What size shot?
TypeS860
Jan 10, 2026 11:11 AM
cycdaniel
Dec 17, 2019 10:58 AM
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
