Issues turning car on
Old Jan 14, 2013 | 05:52 PM
Mopply's Avatar
Hi I have a 2001 Acura CL-P and ever since the "cold" weather started hitting, I've had a problem. This problem has only happened twice but I feel like it'll happen more.
Basically I'll go unlock the car, get in the car, then try turning it on. No cranking, nothing. So I get out of the car and the battery is properly connected, then I unlock the car and the lights go on and all that. Then I try turning on the car again and it works perfectly fine. Is this a battery issue?
Old Jan 14, 2013 | 10:25 PM
oreo615's Avatar
Are the terminals on the battery corroded? How old is the battery? if you have another battery to swap and try from trouble shooting purposes that might give you an answer on the battery condition..
Old Jan 15, 2013 | 12:14 AM
Mopply's Avatar
Not corroded. The battery might be wearing down. The problem is that this event is so random that I can't really test it.
Old Jan 17, 2013 | 03:47 PM
aznboi2424's Avatar
Might have something to do with the car assuming your in anything but park or neutral.
Old Jan 17, 2013 | 07:54 PM
brian6speed's Avatar
Lone Wolf
I would say test the main relay. It is a common issue that acts up in cold weather. I had this issue a few months back. My car would crank but not start.
Yours sounds a lil different than mine tho. If it won't crank at all I'd say test the starter.
Check battery voltage.
You just gotta start with something and test everything possible till you find issue.
Old Feb 4, 2022 | 01:29 PM
psheu's Avatar
I think the OP lives in Bulgaria and's trying to get an RLX SH to drive there. There are no dealership or support for RLX where he lives. That is why he's inquiring about car driving without the hybrid battery if it goes bad.
Old Feb 4, 2022 | 02:49 PM
Pair of TLs's Avatar
Post may be on the wrong thread...
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
