installing DRLs, need 12v power
Old Oct 17, 2015 | 04:01 PM
DLntheCL's Avatar
I need to tap into a 12v source in engine bay, can anyone help me with a wire or fuse i can tap into? everything ive tried is constant power, i need either ignition or cranking source power instead. thank you
Old Oct 17, 2015 | 04:07 PM
run an add a fuse from one of the engine fuse boxes? Perhaps wipers?
Why not tap into turn signal circuit perhaps?
Old Oct 17, 2015 | 04:52 PM
DLntheCL's Avatar
i will give it a shot thank you
Old Oct 17, 2015 | 05:52 PM
DLntheCL's Avatar
I'm already tapped into turn signals. They are dual drl/turn signals. Everything I've tried in the bay fuse box is constant and drls stays on even without key in ignition. Wiper blade fuse must be in interior, I didn't see it
Old Oct 17, 2015 | 06:47 PM
Turn signal may be on without key in ignition but should turn off when you lock car. What exactly are you trying to accomplish so we can better assist
Old Oct 17, 2015 | 07:01 PM
DLntheCL's Avatar
LED Lighting: XSB LED Halos Guide - DIY Installation Guides go to part 4 option 1. I even ran a long wire to the head unit fuse and the DRL still stays on without key in ignition..the only thing i can think of to do is buy something for the 12v accesory port in the center console, not sure what its called but i saw it at walmart, basically using that as the 12v source, and tuck the wire.
Doc.Hollow
Jul 5, 2020 01:38 AM
RainCityCLS
Oct 28, 2015 12:01 AM
stizzylita
1G TSX Problems & Fixes
Oct 15, 2015 02:28 PM
stizzylita
Oct 14, 2015 11:18 PM
