How to Install S/C Belt?
Old Jun 2, 2010 | 10:09 PM
payj's Avatar
Hello,
I was wondering how to install the supercharger belt on my 01 CL Automatic. Are there specific things to do besides unbolt/loosen the old belt and put the new one on? Specific lb torque specs or anything like that?
Overall just how to do it.
Thx
Old Jun 3, 2010 | 12:46 AM
CL-Future's Avatar
Lives in Boost
From the Comptech instructions:
Step #15 Blower Belt Installation:
• Loosen the blower tensioner bracket bolts (B) and move the tensioner and pulley rearward and up.
• Install blower drive belt. The tensioner pulley will
tension on back (smooth) side of drive belt. (See
Diagram)
• Belt tension can be set with moderate pressure on a
19mm end wrench on the flats on the tensioner pulley
plate (A). Once belt tension is set, torque the
bolts (B) to 15ft-lbs.
• After about 100 miles of driving you will need
to recheck the belt tension. You should check
the belt tension at every oil change.
Let me know if you'd like me to email you the .pdf
Nathan Allan
Jul 1, 2023 06:33 AM
vaughanml2
Nov 1, 2021 10:16 AM
stalloutboy
Apr 25, 2016 10:28 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
asahrts
Sep 4, 2015 05:55 PM
