Horn problems
Old Jan 18, 2009 | 12:00 AM
03CL6spd's Avatar
3rd Gear
Horn problems
i have recently installed a new aftermarket horn in my car...when i was toying around and honked it rapidly...after the third honk, i wasnt able to honk the horn again. i checked the relay and there is no problem with it.. what else can i do to get my horn to work again?
thanks
Old Jan 18, 2009 | 12:37 AM
civicdrivr's Avatar
Did you wire it into the stock horn or onto a seperate button?
Old Jan 18, 2009 | 12:12 PM
03CL6spd's Avatar
3rd Gear
i wired it into the stock horn so that all three go off together...
Old Jan 18, 2009 | 02:42 PM
Zippee's Avatar
Check the fuse.
Old Jan 18, 2009 | 03:26 PM
fuzzy02CLS's Avatar
The horn fuse might be blown or you shorted something. What kind of horn? Is it powered? How is it wired?
Old Jan 18, 2009 | 03:59 PM
03CL6spd's Avatar
3rd Gear
there are no fuses for the horn in any of the three fuse boxes... i checked the relay by switching it with the light relay, and it works fine.
are there any other fuses that are not in the fuse box that connect the horn and the horn button in the steering wheel.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
