hid grounding issue?
Old Aug 29, 2011 | 06:34 PM
Bham03TLs's Avatar
Exclamation hid grounding issue?
alright so i have an 03 CL S and the other day my passenger headlight starting flickering, so to figure out the problem i took out my TL S passenger light with aftermarket hid kit on there and installed them on the CL. well i got no power to the low beam on passenger side but driver side works perfectly. and then i hooked the old factory balast back on to see if was gettin power and the same flickering occured... therefore i definitely had power running through the line. Could this be a grounding problem on the passenger side? if so, how would i go about to find the issue? any help is much appreciated.
Old Aug 30, 2011 | 11:34 PM
celynka's Avatar
Sundance Gold in
Sometimes it is an oxidation on 20a fuses. There is a separate fuse for each side. Get new fuses and put them in and out few times. These are located in the long box by pass side firewall
Old Aug 31, 2011 | 10:40 AM
Bham03TLs's Avatar
Heres an update... I took it to a mechanic had him test everything for power.. Im getting power all the way up to the light socket but when I cut the headlights on, passenger side low beam or highbeam still wont turn on. And then I lose power running to pass. headlight. Im gonna try switchin the fuse but the mechanic checked fuses and they were still reading good but ill give it a try. He also said it could be a short circuit somewhere. PLEASE HELP! Thanks.
Old Aug 31, 2011 | 11:36 AM
Bham03TLs's Avatar
Okay headlight fixed after a day of tearing apart cl and tl for hids, factory hid was still good... It was a fuse not a grounding issue. Replaced fuse and got all power back to the pass. light.
Old Sep 5, 2011 | 08:16 AM
AcuraGman's Avatar
Which fuse was it?
tman570
Jun 11, 2019 07:56 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pozebly
Sep 23, 2015 07:30 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
Silverstead1
Sep 17, 2015 06:45 AM
