gauge cluster bulbs
Old May 28, 2010 | 03:58 PM
PDGCLS01's Avatar
gauge cluster bulbs
I have a few bulbs that i guess went out when i took off my dash trim and removed my cluster. Does anyone know the acura part number and if there is an aftermarket equivelent of this bulb? Im not looking for an LED swap just a replacement bulb. Thanks for your help. Also what kind of bulbs do the sunroof and climate control use? one side of my ac controls dont light up and my sunroof and cruise doesnt light up. Thanks in advance.
Old May 28, 2010 | 07:52 PM
aznboi2424's Avatar
Just buy them from the dealer or from part vendors online/on here.
the part number for the sunroof bulb is 35861-S84-A01
the part number for the cruise control backlight is 35861-S0A-T01. The light when its "on" is 36776-S0K-A01
I need more info on what side is out for the AC cause theres 3 different bulbs that the unit uses.
Old Jun 1, 2010 | 08:43 PM
PDGCLS01's Avatar
The actual temp display is out and auto and off button are out as well
Old Jun 1, 2010 | 10:26 PM
aznboi2424's Avatar
Im going to guess that you have non-navi?
The parts diagram isnt helping too much but its either 79671-SW5-941 or 35851-SP0-911. Both those bulbs are for the AC controls, I just dont know what fits behind where. You should probably take the bulb out and bring it to the dealer to confirm.
Old Jun 4, 2010 | 03:42 AM
Dunpeal's Avatar
9th Gear
I have the same problem with my emergency light button and some air condition buttons.
I do not have the resources for DIY. Would it cost too much to have it done?
Old Jun 4, 2010 | 09:23 PM
aznboi2424's Avatar
you should post in the socal thread and see if some local members will help you.
If I were in the LA area, I'd help you out. Its not too difficult for me, just treat them to lunch or something.
Old Jun 5, 2010 | 04:30 PM
Dunpeal's Avatar
9th Gear
Thanks... Will look into that...
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
