Gas for 03 CL type s
Anyone know or have any experience with mixing the gas...eg say if you mix an 89 with a 93 octane... result 91.? I also can get non ethanol gas...can you use an 89 vs a 91 if no ethanol? Tks!
B A N N E D
also 91+ with or without ethanol, doesn't matter
and you will proably see better fuel mileage (and power)with no ethanol in the gas , so i would go for that one
ethanol is cheaper for the oil companys to produce then striaght gas which is partly the reason they like it so much
and as far as mixing you should get 91 when mixing 89 and 93 together if done in a perfect 50/50 ratio
lower than recommended = power power and fuel economy..
hey if u have a CLS use 91 and up. reason being is that the cls has hotter pistons meaning higher compression. and also has high lift cams in comparison to the regular cl motor. 89 octane can cause detonation if u have enough carbon build up in the cylinders. remember 93 is harder to burn than 89. 89 has a better chance of being lit by a glowing piece of carbon deposit in the cylinder that 93. Detonation is bad!!!!!!!!!!!!. don't take the chance.
OculiAquilae
11-19-2018 02:24 PM
sockr1
10-01-2015 01:31 AM
