Front suspention clunk
Old May 4, 2007 | 08:44 PM
OneUpYou's Avatar
Stand Up , Stand Out
I've got a clunking sound coming from my front left corner when I go over bumps and it's getting worse. I'm thinking Ball joint or Wheel bearing....... Any ideas? Anyone else have this happen to them. Common problem?
I'm NOT lowered
03 CL-S 6MT
Jason
Old May 5, 2007 | 05:47 PM
t0p_sh0tta's Avatar
Ball joints and wheel bearings usually make noise while driving, and not just going over bumps.
Check the sway bar end link and strut for leakage.
To check the balljoints and wheel bearing, get the wheel off the ground and grab it at 12 and 6, and 9 and 3. Give it a stern wiggle and see if anything moves. If it does't have somebody give you a hand and see where the "slop" is coming from.
p.s. It wouldn't hurt to throw it in neutral and spin the wheel to see if the bearing is making noise.
Old May 6, 2007 | 10:58 AM
OneUpYou's Avatar
I'll give it a shot and let you know
thanks
Old May 6, 2007 | 11:29 AM
03_CLS_6sp's Avatar
I had a similar noise that went away when I installed new struts - my driver's strut was blown. Other than the noise, I couldn't really tell.
Old May 8, 2007 | 09:43 PM
OneUpYou's Avatar
Well Acura said it was the upper control arm....... Kinda weard no.
Old May 8, 2007 | 09:45 PM
JohnBlayz142's Avatar
Keeping the Stealth alive
I've heard so many complaints about this...I think everyone's situation is different...one of my friend's mentioned he got all his front nuts/bolts torqued to spec and it helped.
Old May 12, 2007 | 02:15 AM
celynka's Avatar
Sundance Gold in
upper control arms always go first.
Old May 15, 2007 | 09:55 AM
dshearon's Avatar
I am having the same issue.... only happens when accelerating from a dead stop or breaking. I dont think it would be the CV's or the bearings as those should make noise during constant motion as well. maybe a blown strut or ball joints.
Old Jun 9, 2007 | 03:21 PM
dannypio's Avatar
Me too
I'm getting the clunk on front left as well. Car is due for inspection so we'll see. I actually don't like getting ripped off at the dealer, so will go elsewhere. Do regular part stores have access to, say, upper control arms, etc., for these cars?
Old Jun 10, 2007 | 03:25 PM
OneUpYou's Avatar
Ya they just have to order them in. Let us know what the problem is when you find out.
Feb 25, 2020 09:57 AM
marcelft
Jul 10, 2018 06:17 PM
Sep 17, 2015 10:16 AM
1Lieutenant
4G TL Problems & Fixes
Sep 10, 2015 08:39 AM
08 NBP TL
Sep 8, 2015 08:49 PM
