Engine/Electrical Problem
Old Jul 5, 2008 | 05:15 PM
nothinbutnet710's Avatar
I have an 2003 Acura CL Type S Manual w/navi and recently, while I'm driving, the engine and all the gauges will shut off without notice. I would normally have to coast to the nearest gas station or emergency lane and wait 1-2 minutes to restart the engine. If I try before that, the starter cranks, but the engine does not turnover. The car does not sputter or anything before it turns off, it just randomly shuts off. I thought it was a battery problem, but the radio, A/C, and navigation stay on. When the engine shuts off, all the needles go down and my digital gauge turns off. Does anyone have any idea of what could be causing this problem? Any ideas would help. Thanks.
Old Jul 6, 2008 | 12:43 PM
m733l's Avatar
i had a similar problem. i have a manual and i would die randomly, but i was able to start it back up while cruising. i cleaned out the IAC valve and it seemed to have fixed the issue. you can try to clean it with some carb/throttle cleaner or replace with a new one.
Old Jul 7, 2008 | 08:39 AM
fuzzy02CLS's Avatar
That, or a bad ground cable or connection. Get your battery tested as well.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
