digital dash blackout (A/C screen)
Old May 12, 2006 | 06:49 PM
mikamoo's Avatar
My car died. I replaced the battery. Car died again. I replaced the alternator. Car died again. Got battery re-charged. Car died again. mechanic found a short in the trunk (trunk light) which was causing the drain on my battery.
NOW... my CL stays charged and is running, but the A/C-climate control area of my dash is blacked-out. Mechanic can't figure out how to fix. Fuses check out ok. Acura says there is no reset for this. Someone mentioned a light bulb, but it's digital! Is that right?
Has this ever happened to anyone and what was the fix?
$600 in the hole, broke, and desperate.
Old May 17, 2006 | 11:20 PM
AegeanCl's Avatar
Since your broke and sound desperate. what you could try is to remove your dash find the wires that connect to the climate control and test them to be sure that there is a positive current going to the climate unit
Downside to this is it wont definately solve your problem and taking the whole dash out will be a bitch
Old Jun 4, 2006 | 05:56 PM
1_fine_02CL's Avatar
4th Gear
It may be a light bulb. When I first got my CL the digital clock would not light up. It finally bothered me enough that I took apart my dash and I found the burnt out bulb. The one for the clock has a flat plastic back and it twists out. I'm sure it is probably the same one, or very similar, for the A/C display. I will warn you though, in my opinion, CL dashes can be a big pain to remove compared to others that I've dealt with. And the area you need is not very easy to access with out removing a lot of screws, clips, etc.
Biggie_B
May 27, 2025 05:51 PM
tsx_boy
Dec 13, 2019 08:33 PM
hashbrown
Sep 29, 2015 12:13 PM
2Quik
Sep 23, 2015 01:03 PM
eastcoastguy
Sep 23, 2015 06:29 AM
