did I miss something?
Old Aug 29, 2011 | 01:34 PM
sc13's Avatar
8th Gear
Disconnected battery to change low beam HID. Now, no power to audio after re-connecting? Did I miss something? All seems to be exactly as I remember. Checked fuse, not the problem. Missing a connector maybe?
Clues would be a help.
Old Aug 29, 2011 | 01:35 PM
sc13's Avatar
8th Gear
sorry, vehicle is 01 3.2 CL. no navi.
thanks.
Old Aug 29, 2011 | 01:40 PM
fuzzy02CLS's Avatar
No power at all or is it asking for the radio code? You have to enter the radio code to get it to work after a battery disconnect.
http://john-perry.com/acurazine/docu..._new_items.pdf
Old Aug 29, 2011 | 02:11 PM
sc13's Avatar
8th Gear
no power. no lighting. no sound.
power outlet , which is on same fuse, works perfectly.
Old Aug 29, 2011 | 07:17 PM
oreo615's Avatar
Look in your owners manual see if your radio code card is in there,when disconnecting battery, radio code needs to be entered
Old Aug 30, 2011 | 08:47 PM
sc13's Avatar
8th Gear
code is not the issue. power to the audio system is the issue. I have radio code. not the first time battery has been disconnected. not getting any juice to the audio. no back light. no CODE in display. no display! power to aux outlet in dash (lighter). security system light does not display either.
Old Aug 31, 2011 | 07:44 AM
fuzzy02CLS's Avatar
Did you check the fuses at the passenger side fuse panel? There's one labeled MEM I think it is. That might have blown.
Old Aug 31, 2011 | 08:30 AM
StreetKA's Avatar
+1
Old Sep 12, 2011 | 03:44 PM
sc13's Avatar
8th Gear
still frustrated with this. Checked fuse. perfect. checked connections (all I could find). perfect.
Now, I have a bad ballast (HID inverter) on the passenger's side. Could they be from the same issue?
This is killing me, since this is my daily driver...And my iPhone loses signal for about 20 miles of my commute...
Old Sep 13, 2011 | 11:41 AM
Bonkz's Avatar
Ok, this may sound silly, but check your wiring for any exposed/striped wires that may be crossing or shorting on the body. I had an issue like this on my Mustang many years ago where a short to my rear defrost (an exposed wire) was contacting the body and completely knocked out all my rear running lights. Electrical tape (temporary) and the all of a sudden I had power to the lights again.
If not that, get out your multimeter and see if there is power after the fuses. If yes, then there may have been damage to your deck for whatever reasons. If no, then trace back thru the wiring until you find the break.
You can also get a little pen-style current detector ($5 makes a chirping noise if it detects current in a wire) that picks up smaller (12v or less) currents and see if there is a live current going through to the deck itself under the dash. (without having to remove the deck itself)
Old Sep 13, 2011 | 11:45 AM
Bonkz's Avatar
Absolutely! Electrical in a car can be a nightmare to diagnose.
tsx_boy
Dec 13, 2019 08:33 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
dainmezron
Oct 16, 2015 06:56 PM
marinrain
ILX
Oct 6, 2015 12:36 AM
