D2R replacement
Old Oct 22, 2011 | 07:36 PM
RSpyder's Avatar
D2R replacement
Anyone have trouble replacing the stock d2r bulb with aftermarket ones? My Passenger side is being difficult to push in and turning to lock it in place...any help/tips/advice? For sone odd reason my passenger connector is red and driver side is black. Is that normal? Low beams are also flickering and not staying on( mostly driver side) bad ballast???
Old Oct 22, 2011 | 07:49 PM
civicdrivr's Avatar
Sounds like the ballast. What do mean turn in and lock?
The D2R bulbs just slide in, then you push the spring lock down and thats it. The only thing on the bulb that you turn is the igniter.
Old Oct 22, 2011 | 08:08 PM
hotclick56's Avatar
2023 TLX
HID flickering usually means a blown 20A fuse (experienced this on my 03 CL). The OEM connector is usually black. After market ballast (like Morimotos) have red & black connector. Make sure the spring is in the open position & swung all the way back before inserting the new bulb.
Old Oct 22, 2011 | 10:59 PM
RSpyder's Avatar
The ignitor requires the back of the bulb with the two prongs to twist in
I'll try the fuse and take pics
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
Billu99tl
Sep 13, 2015 11:30 AM
