CL-S Manual tranny questions
its hydraulic and what power are you puting down ? i would go stage 3 or oem, or oem with p2r disc as for the website i suggest
http://www.excelerateperformance.com/
On;y reason I ask, is because it goes into 1st fine. Just hard to shift into other gears. So i'm thinkign the clutch isn;t fully disengaging. Which would be either I need a new clutch & or new hydros. So i figure while in rome fix both.
Do a fluid change first. Check the clutch fluid reservoir too. To make sure the clutch is holding, put it into fourth at about 25-30mph and floor it. If it gains speed in relation to the RPMs its not the clutch.
mugen_kid
11-13-2015 10:38 PM
HeloDown
09-08-2015 06:51 PM
