Check engine light!?!
So I had the maint. rqd light come on. I went to AutoZone and it passed all codes. Would you fellas do anymore than that? I still have to reset ECU...Do I just unhook the negative battery cable for a minute? Thanks
Yes!
I'll save you from massive flaming..............
The maintenance required light is a dummy light that says you need an oil change. That's it. Reset sequence can be found in the FAQ at the top of the forum. Or the owners manual.
The check engine light is a different light. Looks like a little engine.
HeloDown
09-08-2015 06:51 PM
