Car idling problem and malfunction light
Old Sep 5, 2009 | 03:58 PM
CLSspeedx's Avatar
Hello everyone... sitting in my car in a parking light now hoping for some help...
Today I swapped out my battery for my optima battery and while I was under the hood I cleaned the cone air filter the previous owner decided to just attach to the intake. I also opened the top cover of the engine to look into the intake because my mechanic had found a large amount of carbon buildup a few days ago and cleaned it... A picture of the inside of the intake follows, as I noticed the rightmost "chamber" still black:
Now my problem... Just took the car out and it started to isle up and down between about 750 and 1500... Now it pretty much idles consistently at 1500 and eventually I hear a slight thumping, like something opening and closing under the hood. A friend said he thought it was the iac valvle but IM wondering if it could be something needing to be cleaned again?
Thanks in advance.
Oh, the orange "malfunction" light (that looks like a transmission) is also on.
Old Sep 5, 2009 | 07:59 PM
CLSspeedx's Avatar
Update... Some additional throttle body cleaning, as well as the idle control valve, and I seem to have gotten the idle back under control! The light is still on, but I just seafoamed my car and am reseting the ECU. Car is definitely running better now than when I picked it up.
Old Sep 6, 2009 | 10:12 AM
3.2VtecTL's Avatar
go to any auto store, and get them to see why your Check engine light is on....
it will help diagnose what issue your having...
Old Nov 23, 2009 | 07:30 AM
CLSspeedx's Avatar
Solved.
idle problem partly due to a the smallest vacuum line to the back of the intake not seated correctly...
check engine light came from a small piece of carbon I'm sure.... After I floored it to pass someone it cleared itself
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
