Car Is Humming!!
Old Apr 15, 2009 | 10:33 AM
CLPimpin114's Avatar
Tokin up in
Car Is Humming!!
Hey guys, My car is making a weird Humming noise when turned on. I can hear it all the way into my house. Happens most of the time,wheather its cold or warm out. Ne1 here have ne Idea? Might have to take it in to Dealer and have her checked out
Old Apr 15, 2009 | 11:25 AM
TOPHER33884's Avatar
If it is humming for a short period as soon as you turn the key and crank....it is your fuel pump priming. And then the other humming noises you will hear are the ABS modulators.
Old Apr 15, 2009 | 12:36 PM
NSXNEXT's Avatar
can you determine where the humming is coming from? Maybe a loose belt?
Old Apr 15, 2009 | 01:27 PM
FiftyFive's Avatar
Moderator Alumnus
+2 on fuel pump. My TL used to do this, though not loud enough that i could here it from inside the house.
Old Apr 15, 2009 | 01:40 PM
Tokin up in
Sounds like it coming from center of Engine. Wont Hum when car is started, only after its been on for about 5 mins. My older bro has even noticed it.
Old Apr 15, 2009 | 01:57 PM
civicdrivr's Avatar
Radiator fan?
Old Apr 16, 2009 | 08:20 AM
Tokin up in
I sure hope so!! Taking her in to see the Doctors (Dealer) lol. Will looki at Fans later today when i get home.
Old Apr 16, 2009 | 10:35 AM
Could also be the dreaded Power steering whine/humm that some of us members experience.
Old Apr 16, 2009 | 10:54 AM
bigmark89's Avatar
I Blaze Up In
Do you still have your stock airbox? If so did you do anything to it recently? Last year when I put a K&N filter in my airbox, I broke off the 2 pieces on the bottom part of the airbox that locks the top. And when that happened, it never got a good seal and it hummed like crazy.
Thats the only thing I can think off for the type of humming you are describing. Its a constant loud humming coming from the engine and thats exactly what I had so thats my
-Mark
Old Apr 16, 2009 | 12:30 PM
Tokin up in
I do got a k&n dropin. And Ya! there is a clip broken. Could this be my Problem?? I'll check it out later today.. I hope its not power Steering.
Old Apr 16, 2009 | 01:12 PM
bigmark89's Avatar
I Blaze Up In
Then I guarantee that its your airbox, thats exactly what happened to me.
Your gonna want to replace the bottom part of the airbox. Heres a link to buy it
http://www.acuraoemparts.com/delray/jsp/srchrslts.jsp?vinnosrch=&srchwords=17245-PGE-A00&radiobutton=radiobutton&catcgry1=&inputstate===
Its only about $40 and should'nt take you too long to swap
EDIT: Just to confirm that it is the airbox, start your car and while its running press down on the airbox in different directions. If the sounds muffles when you press down on it then its your airbox.
Good Luck
-Mark
Old Apr 16, 2009 | 01:17 PM
krazykrnboi's Avatar
Wide Body 3.2 CL-S
+1 on the airbox... same thing happened to me.
Old Apr 17, 2009 | 09:22 AM
Tokin up in
LOL Yup! Its the Air Box . Weak man! Just might get Coldair Intake Put in. Then again it wouldn't be a bad idea to have an extra Part. Thanks for the Link man.
Old Apr 17, 2009 | 11:42 AM
bigmark89's Avatar
I Blaze Up In
Your Welcome Dude . Id say go for the intake and just look for an airbox on the Black Market and save yourself some money, ive seen a couple of guys sell their stock airboxes before. Cuz your most likely gonna wanna sell the car as stock as possible, so you'd have to replace the bottom part of the airbox
-Mark
Old Jul 3, 2009 | 12:03 PM
johnnyblazes's Avatar
3rd Gear
humming noise
your airbox is broken or the screws holding your lid down are busted the prics that did my tranny broke mine so i just replaced it with a cold air try pushing down on the cover i bet the noise goes away
peti1212
ILX
22
Jan 5, 2022 05:14 PM
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
