Bulb or Invertor or ?
Old Jun 21, 2006 | 09:23 PM
Black03CL-S's Avatar
Hey guys, my passenger side headlight isn't coming on. It doesn't appear to flash or flicker at all. I've searched on the site and found quite a few threads about this issue, but also found a lot of conflicting info. Can anyone with some knowledge about this (I don't have any!) please tell me if this sounds like just the bulb or something else? Thanks for any info.
Old Jun 22, 2006 | 08:51 PM
TOPHER33884's Avatar
Well, it has happened to me also.......my passenger lowbeam (xenon) light went out allof a sudden.......It was already turning purplish, and I have heard theat this is a sign of a bulb burning out. Like I said, it went all of a sudden, no flashing and no flickering.
Old Jun 22, 2006 | 09:31 PM
It was my lowbeam also. Did you replace the bulb yourself? Do you remember how much that cost? I've only had my car a few months and this is my first car with the Xenon bulbs.
Old Jun 23, 2006 | 12:39 PM
Well, I cant say that I did it myself. My freind owns a body shop, and I get all of my labor done for free, all I pay for is parts. get your HID's off of EBAY.
Old Jun 23, 2006 | 01:05 PM
NSXNEXT's Avatar
Easiest way to test is swap the bulb from the other side.
Old Jun 25, 2006 | 09:09 PM
Thanks for the advice. If it is indeed the bulb I will buy off of Ebay. What do you consider a fair price for a bulb or pair of bulbs? Is it best to stick with the stock wattage bulbs, or do most of you guys upgrade? Thanks again for any advice.
Old Jun 26, 2006 | 06:48 AM
I myself went with the 6000K bulbs...........give off a nice blue hue at might time! especially when heated to full temp. Go for those, and you wont be disappointed.
Old Jun 27, 2006 | 10:57 PM
From what I've read on here the 6000K bulbs seem to be the best overall.
Old Jul 3, 2006 | 07:18 PM
ZBlackCLS's Avatar
9th Gear
My passenger side low lamp is out intermittently. Do the lamp receptacles turn and remove from inside the engine compartment behind the light assemblies? And do the bulbs pull out of the receptacles or what? Thx for any info.
Old Jul 6, 2006 | 09:37 PM
I wish I knew the answer, but I've only had my car a couple of months and I'm not very mechanically inclined. If anyone has more info please let us know.
Old Jul 22, 2006 | 08:32 PM
Update
I was due for an oil change so I took the car to the dealer last week and asked them to look at the headlight problem. The bulb was fine but the fuse was blown. They said it kept blowing fuses when they replaced them. It turns out the inverter was bad. Somehow moisture had killed it. Luckily it was covered under warranty, but that would have been a little over $500 repair if not.
hashbrown
Feb 18, 2022 11:20 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
h22lude
Sep 27, 2015 06:22 PM
ripit
Sep 26, 2015 06:19 PM
eastcoastguy
Sep 23, 2015 06:29 AM
