Brake Squeeeeel
Old Jul 29, 2016 | 09:19 PM
01CLOwner's Avatar
Brake Squeeeeel
I just put new rotors and pads on the front of my 2001 CL Type-S. I took it for a test drive and now have a very high pitched squeal while driving. Constant. It sounds like metal on metal and not typical brake noise.
There are clips in the caliper that sort of hold the pads in place and I am guessing that is what's rubbing against the new rotor. That's a guess, I didn't pull the wheel after the test drive.
Anyone else have this issue?
If that is the issue, what about removing those clips? I've had several different vehicles that don't have those on the calipers, the pads just slide in and are held by the piston.
Thanks.
Old Jul 30, 2016 | 05:50 AM
coopcoop30's Avatar
Could you have bent the dust shield while installing the rotors and brakes? It could be scraping as the rotors turn. Try bending it away from the rotor.
Old Jul 30, 2016 | 04:32 PM
01CLOwner's Avatar
It's possible, but not so sure I did. I'll check that when I pull the wheels.
Thanks for the heads up
Old Jul 31, 2016 | 11:01 AM
01CLOwner's Avatar
Pulled the wheel and saw that the dust shield was bent inwards a bit but not making contact. The clip holding the pads in was a bit wanky and that was the culprit. A little bending and snipping and the squeal is gone.
Thanks.
95oRANGEcRUSH
Jan 7, 2024 07:05 PM
usdmJON
ILX Performance Parts & Modifications
15
Sep 8, 2016 12:04 PM
Skirmich
1/2G MDX (2001-2013)
Aug 3, 2016 02:11 PM
tealt
Mar 26, 2016 02:00 PM
Acuraneewb
Mar 7, 2016 01:50 PM
