Brake Light stays on
Old Jan 5, 2006 | 07:58 PM
smooth CL-in's Avatar
Registered CL-er!
Happy New Year to All.
Still new to the site. I want to be more active on Acurazine for 2006 and beyond...Anyways I have a 01' CL- S When I start the car in the morning the brake light stays on for a long period of time then goes out. The brake fluid and brakes on the car are fine besides a little warp in the rotors. Do you think this is due to the E-brake switch or should i have the brakes checked? Does anyone encounter the same problem?
Old Jan 6, 2006 | 04:31 PM
CL'er 1st & 2nd Gen's's Avatar
Acura loyal for 93mo/109k
Try a search. The sensor is a common culprit.
Old Jan 6, 2006 | 07:41 PM
Registered CL-er!
Thanks, I'll give that a try.
Old Jan 20, 2006 | 05:20 PM
TypeS_boi's Avatar
CL-S retired 10.17.06
Same issue here,this just came up last night. temps last night was about 47 degrees, started car and drove for about a mile and the brake light indicator came on, stayed on for about 2 mins and finally off.
Old Feb 16, 2006 | 09:39 PM
adamrevious's Avatar
3rd Gear
Brake Light
Hello,
I am sure you have all gotten your problems solved by now, but just in case what cases that is a faulty screen in the master cylinder. If the screen is not working properly and letting the fluid through like it should the car thinks the fluid is low and trips the light.
Old Feb 17, 2006 | 08:45 AM
phipark's Avatar
Not Asian
Originally Posted by adamrevious
Hello,
How or can you change this screen easily?
Old Feb 18, 2006 | 03:01 PM
3rd Gear
I am not really sure how long it takes to be honest. It cost me 80 bucks to have them do it at the dealership. it was only like a 10 dollar part and the rest was labor.
Old Feb 20, 2006 | 07:02 PM
Tosh's Avatar
Eurotrash
While the light is on, go tap on the brake fluid reservoir cap, and see if it goes off. Rules that out.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
PortlandRL
Sep 14, 2015 12:01 PM
Birdflunuggetz
ILX
Sep 14, 2015 07:00 AM
