ball joint question (need advice)
Old Dec 3, 2008 | 11:31 PM
fantom's Avatar
Guys can someone help me out here . I just checked the suspension and found out that the left , front balljoits is torn (Rubber ) . I whant to place the order online but confused ..it is the lower one or upper. cant find the picture anywere ...can someone tell me how to find out..
Old Dec 4, 2008 | 03:05 AM
YeuEmMaiMai's Avatar
it's usually the lower joints that take the most abuse and you can tell which one is which as the lower one is at the bottom of the spindle
Old Dec 4, 2008 | 03:11 AM
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Dec 7, 2008 | 05:48 PM
djarovsky's Avatar
And you don't need to buy the entire knuckle assy either. The ball joint is available separately now. Info in the following TSB. It will save you a lot of money, both labor and parts.
http://www.in.honda.com/Rjanisis/pubs/SB/B06-015.PDF
Old Dec 8, 2008 | 12:53 AM
^sweet
Old Dec 15, 2008 | 07:51 PM
pits200's Avatar
But you will need to take off the entire knuckle and have the lower ball joint pressed in. This isn't a job that can be done without a machine shop.
Well atleast I wasn't able to.
Old Dec 16, 2008 | 10:27 PM
civicdrivr's Avatar
Heat + a Big Fucking Hammer. Worked for me on my previous cars.
Old Dec 17, 2008 | 02:04 PM
NSXNEXT's Avatar
The labor will certainly be more since you have to remove the old and press the new ball joint in, but overall it should be cheaper. As mentioned, you'd have to find someone that can do that work. Most local shops won't bother.
Old Dec 17, 2008 | 06:48 PM
Oh1TypeS's Avatar
LOL..ahahha
Old Dec 18, 2008 | 08:46 AM
pits200's Avatar
If you have a Napa store with a machine shop attached to it, they did mine for $15. It was some old gruff guy, I brought in the knuckle and he went to town, I tossed him a $20 and he was good to go.
Old Dec 18, 2008 | 08:58 AM
pits200's Avatar
Here is a link that I did when replacing my ball joint.
https://acurazine.com/forums/showthr...ght=joint+ball
jblessing
Aug 8, 2018 09:43 PM
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
V-tecAc
Sep 21, 2015 09:25 AM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
