Ball Joint
Old Mar 7, 2006 | 09:07 PM
truongvo1978's Avatar
Ball Joint
Grease is all over passanger side wheels. The balljoint ruber seal that has grease in it is punctured. I know i am concerned. How big is a problem is this? Should i be verry worried? What does this do to my ball joint?
Old Mar 8, 2006 | 03:24 AM
mr5parkle's Avatar
your ball joint will eventually dry out causing creaking and premature wear of the ball joint. eventually, it WILL fail. the amount of time is relative however. i drove around with NO boot whatsoever for about 20k miles, no problems, but it was always in the back of my head. i replaced it with the ingalls upper control arm.
Old Mar 8, 2006 | 07:49 PM
rondog's Avatar
Former Sponsor
if you jack up the car, grab the wheel from 12:00 and 6:00, then try to wiggle it forward and backward, does it have play?
Old Mar 8, 2006 | 11:03 PM
its like 11 pm right now, i'll check it tomorow after work. should it wiggle? and if it does or does not, what does that mean?
Old Mar 9, 2006 | 08:19 PM
Acutron's Avatar
Skillionare
What does it mean if there is play on the wheel when the car is jacked up...can that be tie rods too?
Old Mar 10, 2006 | 06:03 PM
Acutron's Avatar
Skillionare
pending you don't have grease al over your shit :|
jblessing
Aug 8, 2018 09:43 PM
marcelft
Jul 10, 2018 06:17 PM
Brandle34
Sep 23, 2015 07:20 PM
0opie
Sep 22, 2015 04:15 PM
V-tecAc
Sep 21, 2015 09:25 AM
