AC/Heat Blower Not Working
About a month ago I noticed on my 2003 Type S, that the heat would kick on then shut off, same the A/C.. Now it doesnt blow any air, I can feel it get hot and cold depending on the temp setting, just no variable speeds. I checked the fuse on the drivers side, in the fuse box and I replaced the main relay in the fuse box. I checked under the glove compartment to see if the terminal was melted but it looked good. Any ideas what else I could check? Thanks
Fix for my blower that stopped working. I took my car to the mechanic and he very quickly diagnosed a bad blower motor resistor that is located under the dash. Took a few minutes to replace. My total price out the door with tax was $114, but you can easily buy one at Acura for about $54. It's located somewhere under the passenger side dash and is white ceramic.
mada51589
Jan 9, 2025 04:40 PM
ahsm
Sep 9, 2015 08:35 AM
