3rd gear grinding
Old Sep 9, 2006 | 10:50 AM
cls03cls03's Avatar
CL-S-6-speed
3rd gear grinding
I drive a 03 CL Type-s 6 speed manual.
When I try to shift into 3rd from any gear, there is a grinding noise and the stick vibrates violently. This only happens with the 3rd gear and all other gears are fine. Is this problem fixable or will I have to replace the whole transmission.
Old Sep 10, 2006 | 02:35 AM
Tangsta's Avatar
try topping up/changing your transmission fluid?
Old Sep 11, 2006 | 10:32 AM
PhilB81's Avatar
bent link maybe?
a friend of mine had 91 CRX (beater car) and it started doing that, but his was going into 2nd gear and 5th gear.
Old Sep 24, 2006 | 10:39 AM
Type S Zero's Avatar
worn/damaged 3rd gear and syncro
the 2 gears that fail most of the times are 2nd and 3rd gear (mostly because of hard shifting)
warrantied for 5 years/60K miles
Old Sep 24, 2006 | 02:18 PM
fuzzy02CLS's Avatar
"warrantied for 5 years/60K miles"
What? 4 year/50K miles & is likely past warranty anyway.
Old Sep 26, 2006 | 06:46 PM
here in canada warranty is :
basic : 3 years / 60 000km (4 years / 80 000km on 2006+ models)
powertrain + a lot of other stuff : 5 years / 100 000km
auto tranny : 7 years / 160 000km
1 mile = 1.609 km
Old Oct 6, 2006 | 10:09 PM
BigLizard's Avatar
Moderator Alumnus
Old Oct 16, 2006 | 09:56 AM
mr littlejeans's Avatar
6th Gear
my dealer told me the manual tranny was only on the 4 year/50k warranty.
was this correct?
Old Oct 17, 2006 | 04:16 PM
GreenMonster's Avatar
was this correct?
Yes... The 03 CL 6spd only has a 4 year/50K warranty...
<--- 4 years/ 53K miles now
Old Jan 8, 2007 | 08:43 AM
trewatts's Avatar
CURBS FTL
so this is definitely an unfixable problem w/out getting a new tranny? it does the same thing on my 98 5mt, but only when i redline it. i know its not my fault because i have tried redlining, clutching, waiting a second, then shifting and it still does it. the car has never had a new clutch. could that be it?
Old Jan 16, 2007 | 10:16 AM
you don't need a new tranny, only replace faulty gears with syncros and you'll be fine.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
