2G CL cranks, but starts only after 5+ attempts in 5K ft mtns.
Old 10-16-2017, 10:42 AM
7th Gear
TheFu's Avatar
Have a 2001 CL - around 160K miles. Wonderful car all these years. Always starts right up, except when we visit family near the Blue Ridge Parkway (NC mtns) during high "leaf" season ... mid-October.
The car works great getting there, but it takes 5+ starting attempts to get going. It isn't low temp related - mid-50s over night there still. Always starts fine at home even below freezing.
The starter is cranking fine - very strong. Had over a half tank of 93 octane fuel in the tank, so I wouldn't think it is a fuel issue.
I did move the car once during the 5 days there. It started just fine for that 20 seconds of use around day 3 - that was late afternoon.
Drove home yesterday after finally getting it to start around the 5th attempt. Started right up after a fuel stop at lower altitudes in SC.
Basically, it is just a starting issue in the NC mountains as far as I can tell.
Any ideas? Some dirty sensor somewhere that doesn't seem related? Or should I just wait until next October and plan to get a jump / 10+ starting attempts?
Old 10-16-2017, 10:57 AM
Received 8,611 Likes on 6,650 Posts
Try cleaning the throttle body and checking the conditions of all the spark plugs.
Hows your air filter?
Old 10-16-2017, 05:39 PM
7th Gear
TheFu's Avatar
Air filter was replaced 5k miles ago.
I doubt there will be any starting issue for 12 months - it only happens above 3K ft altitude. We live around 900 ft alt. No issues starting today, back at home.
I cannot recall when the spark plugs were changed last - probably 60K miles ago.
Old 10-26-2017, 01:34 PM
Eurotrash
Tosh's Avatar
First I would suspect a gummed-up Idle Air Control Valve. Second, I would check out the PGM-FI relay (aka Main relay), remove it, and reflow the large solder joints on the pcb inside.
Everything there is to know about your Honda/Acura main relay:
How the Main Relay works
When the Main Relay goes bad
https://acurazine.com/forums/2g-tl-p...-relay-931252/
