2001 cls won't run
Old Mar 13, 2013 | 07:07 PM
Uli93's Avatar
3rd Gear
Exclamation 2001 cls won't run
Recently my girlfriends car overheated . I've replaced the head gaskets and shaved the heads to remove warping. Mechanically it's been repaired . Now the car turns over but won't run. Fuel is being delivered . Plugs have plenty of spark. All fuses are good. Camshaft position sensor has full power. I'm wondering if its the crankshaft sensor. Any body have any suggestions ???
Old Mar 13, 2013 | 08:34 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Did the car ever fire after the headgasket job ?
If not I would think either crank sensor issue or a ground was not re connected.
That's if you have spark and fuel.
Any cel's with the no start?
Old Mar 14, 2013 | 07:42 PM
Uli93's Avatar
3rd Gear
after it was put back together we tried to start it and it turns but wont catch it doesn't even sputter as if it were about to run. just bought a new crank position sensor . it did nothing.
Old Mar 17, 2013 | 11:32 PM
celynka's Avatar
Sundance Gold in
check the crank position sensor plug right by timing belt tensioner. People tend to forget to reconect this one
Old Mar 18, 2013 | 06:20 PM
Uli93's Avatar
3rd Gear
so the honda dealer told me it has no compression in the pistons . could re-torquing the heads fix that? since they were shaved. i doubt the block could be cracked it ran fine before... just over heated thats all we are running out of ideas..smmhhh
Old Mar 18, 2013 | 10:59 PM
celynka's Avatar
Sundance Gold in
could be a bad timing setup
Feb 25, 2020 09:57 AM
Sep 17, 2015 09:01 PM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
Tsov Tom
Sep 6, 2015 07:56 AM
