2001 CL Type-S making front end noise? Weird!!
Old Jan 7, 2010 | 10:36 PM
Seymore Cake's Avatar
'01 Acura CL Type-S
One day I was in CT and it was really cold about 5-10 degrees and I turned my wheel and I heard this squeak sound like wtf is that.....So just before x-mas I had all my tires changed and the problem was gone and also the temperature was in the 40-50 range....Now that the temperature has dropped to the low 20's the noise has come back and its the most annoying thing ever. Front end both sides whenever I turn the wheel...
So has anyone had this same problem??? Might I need to get some things greased up or are my tie rods or struts messed up. Any help would be great, thanks in advance...cause i'm lost
Old Jan 8, 2010 | 11:55 AM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Yeas I had that same problem , my car souded like it was gonna fall apart.
How old are your shocks? My shocks had 140K on them and they where way past shot.. They where a mess , all 4 were leaking bad..way overdue, chaged the shocks and springs (I got B@G shock/spring set for $500 that lowered the car 1 inch) and still had a little noise so I replaced the sway bar links with Moog and the bushings with polyurethane and all the noise was gone. Have u replaced anything to do with the suspention yet, what year is your CL and how many miles!?
Old Jan 9, 2010 | 08:10 AM
'01 Acura CL Type-S
My car is an 01 so its basically 10 years old the car has 157,000 miles on it and I havn't done anything suspension wise...Had the car since august but now I will get it checked out...thanks for your insight
Old Jan 9, 2010 | 08:50 AM
StonedCL's Avatar
B A N N E D
You DEFF need new shocks and prob new Sway bar links
U can get MOOG sway bar links for like $80 for all 4 on rock auto..
You might also need the bushings that hold the front sway bar cuz that rubber and does deterorate after 10 years..
StonedCL's Avatar
B A N N E D
Also shocks are about $80-$100 each for OEM u cen get a kit Shocks/springs for under $500
Old Jan 11, 2010 | 01:54 AM
'01 Acura CL Type-S
Yea...I have to go see my mechanic today...the thing that sucks most about this is that I just had all this work done in the summer on my '99 Toyota Solara SLE before I was in a accident and it was totaled in late September which ran about $800-$1000 with labor and parts....life..what a bitch
Old Jan 14, 2010 | 05:29 PM
umurrjo1's Avatar
5th Gear
My 01 cl makes a humming sound for like 5 secs when i turn the wheel Ill hear it once then nomore when I first drive off.
Old Jan 19, 2010 | 02:05 AM
'01 Acura CL Type-S
So I got my work done and it turned out to be the ball joints and something to do with the sway bar and now my noises are gone....
and UMURRJO1 i get that noise to... no idea what it is though
Old Jan 22, 2010 | 09:50 PM
umurrjo1's Avatar
5th Gear
Ima have mine checked out.....
Feb 25, 2020 09:57 AM
2012wagon
Sep 29, 2015 04:21 PM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
