03 CL-electrical problem after charging laptop
The radio and power outlet stopped working after charging my laptop during road trip....now the power windows acting up and won't work too.
Fuse keeps blowing up every time I install a new 20 amp fuse for the radio and power outlet so I stopped working dilemna till I go to the mechanic shop.
Any ideas where the short circuit could be located fellows...Im going to disconnect/reconnect the battery to reset the ECU if that works or not.
Cool, finally fixed my power jack and radio...had a dime or coin stuck in the power jack causing to short new fuses
now, got to figure out why my power windows and sunroof went out....maybe the short in radio and power jack caused the short in my windows.
anybody using probes to check electrical problems
Hello,
Did you check the fuses for the power windows? If you want the electrical diagrams e-mail me i'll send you the pdf, then you can trace the wires.
superdeals2004@shaw.ca
snorf
Nov 4, 2019 06:44 AM
