01 CL Type S ~ Trans wrks perfect D4 but D5 not so much.
Old 10-17-2016, 10:50 AM
Jason Deglman's Avatar
Hello,
Im new to community. Any insite on why my 01 CL Type S works perfectly in D4 however in D5 shakes/studders at end of gear prior to shifting into 3rd and 4th. If i time it and release the gas pedal just before shifting no problems. But again in D4 works perfectly. Any insite or ideas on how to DIY fix it would b great
Old 10-24-2016, 09:48 AM
jetsfan2016's Avatar
Sorry to hear you are having this issue. Don't know of a DIY. Unless you aren't able to, I would check with a trusted honda/acura local mechanic to take a look.
Old 10-24-2016, 11:55 AM
Received 8,714 Likes on 6,721 Posts
have you replaced fluid recently?
Old 11-18-2016, 12:12 PM
YeuEmMaiMai's Avatar
drain, fill drive around the block, repeat 2 more times.
Old 11-19-2016, 09:06 AM
LechePuro's Avatar
Thanks for the post and the info. I have the same issue with my 01 CL (Not type S-Though I want to do an engine swap). I normally keep mine in D4 until I hit 80 mph, and then switch to D5. As long as I keep the speed above 80 mph the car rides smoothly. 75 mph and the car starts shaking and stuttering, then it's back to D4. More power and response, but killer on gas
Old 11-19-2016, 11:34 AM
01acls's Avatar
You guys need to do the 100 percent ATF exchange and replace the external trans filter.. See the link below.
https://acurazine.com/forums/second-...ission-943471/
If the problem persists after following the instructions in the link then it's time to start replacing solenoids.
Old 12-03-2016, 10:22 AM
RedlineCL-S's Avatar
Same Problem :(
Originally Posted by Jason Deglman
Hello,
I'm having the exact same problem, D5 is horrible in my car, shakes, jerks, studders, so I leave it in d4 until 45mph and shift to d5. I did the proper transmission flush with the proper fluid and changed the external filter and still have the same problem.
Old 12-03-2016, 03:36 PM
01acls's Avatar
Replace the following
1. Shift C solenoid.
2. Pressure A/B solenoid, O-rings, gasket.
3. Pressure C solenoid.
Assuming you've checked the filters for debris under #2 and #3.
Old 12-03-2016, 04:33 PM
01acls's Avatar
Correction, I think I might of misread your question. My last Post #8 above is for issues shifting in 4-5/5-4 gears.
If that's not your symptoms pleasure elaborate in full detail?
mike88se
08-15-2017 08:39 AM
boostedorbusted
06-14-2016 07:31 AM
thinhthan
04-08-2016 01:02 AM
crxmadness
04-02-2016 09:15 PM
GK83
09-13-2014 12:48 AM
Quick Reply: 01 CL Type S ~ Trans wrks perfect D4 but D5 not so much.
