01 cl-s washer hose / line repair
Old Nov 15, 2017 | 12:39 AM
asb32952's Avatar
Product DescriptionPriceQuantityTotalBULK HOSE, VINYL (4X7X8000)
Part Number: 95003-07008-70M
Remove$12.34$74.04JOINT L, WASHER TUBE (DENSO)
Part Number: 76828-SH0-A02
Remove$1.40$1.40VALVE, ONE-WAY
Part Number: 76826-S52-C01
Remove$5.57
Has anyone done this before?
Is the id od of the hose 7 and 12mm?
Everything is brittle.
Florida car.
Which aftermarket dorco? parts work good?
I need part 8 thru 10.
Old Nov 15, 2017 | 09:17 AM
ProfessorFunk's Avatar
Resident Smart@ss
I recently did it for both sides of my '02 TL, also a Florida car, also everything brittle. I don't have the hose in front of me (I'm at work) so I can't check the dimensions, but I'd be happy to mail you a couple feet at no cost. Be advised that if you need to remove the "washer tube clip" (part no 91530-S3M-A00), go ahead and order a replacement because it will break.
https://www.acuraoemparts.com/auto-p...=950030700870m
Old Nov 15, 2017 | 07:56 PM
Resident Smart@ss
It is not. ID = 4mm, OD = 7mm (see attached images).
washer hose inner diameter, 95003-0700870M
washer hose outer diameter, 95003-0700870M
Old Nov 15, 2017 | 10:06 PM
asb32952's Avatar
pm sent.
Old Feb 25, 2025 | 12:46 AM
whitetiger5's Avatar
just adding a note here with some tags so that it can be found easier in the future.
honda bulk hose cross reference guide
found it here previously: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/vacuum-line-diameter-3101975/
95005-35008-10M [ this is a bulk hose, with no numbers printed on it]
95005=type of hose is general applications
35=3.5 mm inner diameter
008=lenght in meters
10M=Gray hose
I took this from motorcycles guides, my guess is that honda have shared parts with cars, I also checked on EPC parts catalogue and the reference ID was the same.
The whole code is described like this
95xxx-yyzzz-w0M
xxx
=== 001- fuel hose
=== 003- vinyl hose
=== 005- vacuum hose
yy
=== several inner diameter starting in 3.0mm
zzz
=== lenght in meters [001,003,005,008]
w
==Fuel hose 2: Red outside braid
===(3 mm inside dia. only)
===5: Black inside braid
===3: Red (3 mm inside dia. only)
===4: Ash gray with red stripe
===6: Black
==Vinyl hose 1: Clear
===2: Black
===3: Light red
===6: Light red
===7: Pale black
==General hose 1: Ash gray
===2: Ash gray
===3: Black
===5: Black
