rp_guy's 2003 CL-S 6MT ABP
'03 ABP YA4-S 6MT
Interior
Hertz 6.5" component front, 6.5" coaxial rear speakers, baffles & rings
Dayton Audio RSS265HO-4 10" 600W RMS 4ohm sub w/ custom ported box
Elemental Designs nine.4 65Wx4 RMS speaker amp, Phoenix gold ryval v8001 600W RMS sub amp
Big 3 upgrade w/ 0 gauge wire, fuse holders, battery terminals
Alpine IVA-W505 touchscreen dvd double din w/ bluetooth & nav
Metra axxess steering wheel control
Boyo VTK350 rear camera
Clifford 5702 2-way remote starter/alarm
OEM Acura CL navi dash
OEM Acura TL rear seat heater vents
PE Tuning short shift kit
XLR8 aluminum pedal set
OEM CL door checkers
All-season mats
JDM Honda S2000 VGS steering wheel w/ RSX airbag
Interior total
Exterior
Custom molded OEM TL lip kit w/ new paint on front/rear bumpers, rockers, mirrors and xpel paint protection
M3 style painted trunk lip spoiler
20% front/5% rear tint
Hella Micro DE foglights
3000K HID h3 bulb fog kit
HIR highbeam bulbs
Airhorns
XXR 527 18x8.75" +35 dark bronze w/ 225/40R18 tires
Exterior total
Mechanical
OEM Acura 02 MDX J35A3 3.5L motor swap
OEM Honda Odyssey 130A alternator
NGK Laser iridium spark plugs
UR underdrive pulley
Gates belts #40425, #60441 for UR pulley
Aasco lightweight flywheel
Clutchmasters Stage 3 clutch/pressure plate/throwout bearing
Corsport aluminum shifter bushings
XLR8 75A engine mounts
Custom poly filled transmission mounts
AEM cold air intake
Comptech headers
Straight pipe axle-back w/ Magnaflow tips
OEM CL timing belt/water pump/tensioner
Ingalls stiffy engine damper
OEM CL clutch slave w/ damper removed
OEM CL clutch master
Moog inner/outer tie rods
Ingalls camber adjustable front control arm 13920/rear links 38720
Progress 24mm rear sway bar
Energy greaseable sway bar body mounts
H&R 51858 lowering springs
Koni sport (yellow) rebound adjustable struts
Timken wheel bearings
OEM Acura Legend Type II front 2-piston calipers
OEM CL manual transmission gears/syncros
Mechanical total
Extras (not installed)
OEM Saab 9-3 painted lip spoiler (new)
OEM 01 CL headlights, painted housing (used)
OEM 03 CL tailights (half red/half clear - used)
OEM CL J32A2 heads w/ KMS valvesprings (used)
ARP headstuds (used)
OEM TL J37 intake manifold (new)
OEM MDX manifold spacer (new)
Blox 76mm throttle body - for use with TL manifold (new)
P2R throttle body/manifold gaskets - for use with TL manifold (new)
OEM Acura RL advics front calipers for BBK w/ custom mounting bracket (used)
Rebuild kit for RL calipers & rear calipers w/ EBC greenstuff pads (new)
EBC rotors front GD7122, rear GD7146 - for use with RL big brake kit (new)
Russell stainless steel brake lines - used with RL BBK (new)
73mm -> 64.1mm aluminum hub rings - used with aftermarket wheels (new)
66.1mm -> 64.1mm aluminum hub rings - used with 350z rotors (new)
Tokico blue struts (used)
Neuspeed short shift kit (used)
Innovative 60A engine mounts (used)
NRG engine dampers set (new)
OEM CL navigation (used)
Dom's unit for OEM CL nav (used)
Metra dash kit for double din (new)
Omnipower 21mm quickclutch master cylinder - reduces clutch pedal height/throw (used)
Custom parts for swaybar endlinks (new)
Various OEM parts (new/used)
3rd gen TL wheels w/ studded winter tires - needed to clear RL BBK
Black market thread for vehicle/parts: https://acurazine.com/forums/member-...mt-abp-936627/
All-season mats
Interior total
Exterior
HIR highbeam bulbs
Airhorns
Exterior total
Mechanical
AEM cold air intake
Comptech headers
Mechanical total
Holy moly
You have THE ultimate CL What an absolute beauty.
Pham Alvan
03-16-2016 09:17 AM
RSpyder
09-30-2015 12:46 AM
