rp_guy's 2003 CL-S 6MT ABP
12 Attachment(s)
Interior
Hertz 6.5" component front, 6.5" coaxial rear speakers, baffles & rings Dayton Audio RSS265HO-4 10" 600W RMS 4ohm sub w/ custom ported box Elemental Designs nine.4 65Wx4 RMS speaker amp, Phoenix gold ryval v8001 600W RMS sub amp Big 3 upgrade w/ 0 gauge wire, fuse holders, battery terminals Alpine IVA-W505 touchscreen dvd double din w/ bluetooth & nav Metra axxess steering wheel control Boyo VTK350 rear camera Clifford 5702 2-way remote starter/alarm OEM Acura CL navi dash OEM Acura TL rear seat heater vents PE Tuning short shift kit XLR8 aluminum pedal set OEM CL door checkers All-season mats JDM Honda S2000 VGS steering wheel w/ RSX airbag Interior total Exterior Custom molded OEM TL lip kit w/ new paint on front/rear bumpers, rockers, mirrors and xpel paint protection M3 style painted trunk lip spoiler 20% front/5% rear tint Hella Micro DE foglights 3000K HID h3 bulb fog kit HIR highbeam bulbs Airhorns XXR 527 18x8.75" +35 dark bronze w/ 225/40R18 tires Exterior total Mechanical OEM Acura 02 MDX J35A3 3.5L motor swap OEM Honda Odyssey 130A alternator NGK Laser iridium spark plugs UR underdrive pulley Gates belts #40425, #60441 for UR pulley Aasco lightweight flywheel Clutchmasters Stage 3 clutch/pressure plate/throwout bearing Corsport aluminum shifter bushings XLR8 75A engine mounts Custom poly filled transmission mounts AEM cold air intake Comptech headers Straight pipe axle-back w/ Magnaflow tips OEM CL timing belt/water pump/tensioner Ingalls stiffy engine damper OEM CL clutch slave w/ damper removed OEM CL clutch master Moog inner/outer tie rods Ingalls camber adjustable front control arm 13920/rear links 38720 Progress 24mm rear sway bar Energy greaseable sway bar body mounts H&R 51858 lowering springs Koni sport (yellow) rebound adjustable struts Timken wheel bearings OEM Acura Legend Type II front 2-piston calipers OEM CL manual transmission gears/syncros Mechanical total Extras (not installed) OEM Saab 9-3 painted lip spoiler (new) OEM 01 CL headlights, painted housing (used) OEM 03 CL tailights (half red/half clear - used) OEM CL J32A2 heads w/ KMS valvesprings (used) ARP headstuds (used) OEM TL J37 intake manifold (new) OEM MDX manifold spacer (new) Blox 76mm throttle body - for use with TL manifold (new) P2R throttle body/manifold gaskets - for use with TL manifold (new) OEM Acura RL advics front calipers for BBK w/ custom mounting bracket (used) Rebuild kit for RL calipers & rear calipers w/ EBC greenstuff pads (new) EBC rotors front GD7122, rear GD7146 - for use with RL big brake kit (new) Russell stainless steel brake lines - used with RL BBK (new) 73mm -> 64.1mm aluminum hub rings - used with aftermarket wheels (new) 66.1mm -> 64.1mm aluminum hub rings - used with 350z rotors (new) Tokico blue struts (used) Neuspeed short shift kit (used) Innovative 60A engine mounts (used) NRG engine dampers set (new) OEM CL navigation (used) Dom's unit for OEM CL nav (used) Metra dash kit for double din (new) Omnipower 21mm quickclutch master cylinder - reduces clutch pedal height/throw (used) Custom parts for swaybar endlinks (new) Various OEM parts (new/used) 3rd gen TL wheels w/ studded winter tires - needed to clear RL BBK Black market thread for vehicle/parts: https://acurazine.com/forums/member-...mt-abp-936627/ |
Looks great. Shame you gotta let her go..
J35 must be a great time though :biggrin: |
Holy moly :drool:
You have THE ultimate CL :2cents: What an absolute beauty. |
A beautiful CL! I always wished you would post more pics. Hopefully she goes to a good home!
I'm confused is this an 03? cause those tail lights look like 02? still nice whip though!
^^ I believe he likes the 01-02 taillights better because the 03's are in the for sale items. Very clean car !!
parts
interested in the saab spoiler, SS brake lines and tokico blues.
PM me prices shipped to 60188. |
great looking set up...love the flat bottom steering wheel
