nspec's 01 CL-S thread
#526
Regional Coordinator (Texas)
The pass sideskirt adjusted to match the drivers, and they'll be finished today for paint
The flush mount spoiler getting the cutout filled in and then paint
#529
the fork is stuck in disengage position. the pedal is stuck down, u can still pull it up with hand, but doesnt make a difference. just got home though, about to jack it up and look at it.
Happy New Year to me.
#532
bad news. looks like it is my pressure plate or throwout bearing.
i took the slave cylinder out and the fork stays in disengaged position and i can move it left and right about an inch easily with my hand.
#536
Whats up with RDX owners?
Hope you get it figured out quick and it turns out to be a cheap throw out bearing and not a pressure plate.
#541
I got the Shifts
hey man. make sure that your pedal is mounted correctly, there is a bolt hole above the pedal bracket that must be attached to the firewall area. it is vertical, if it isnt connected then the pedal rests its weight on the CMC causing premature pp wear and clutch wear.
#542
there is a bracket all the way up with a bolt sticking out that you're suppose to slide the pedal bracket into and secure it with a nut. the automatics didnt come with it and I didnt feel like welding that bracket just because it was gonna be a pain in the ass. I'll have to figure something out so that it doesnt put all of its weight on the CMC.
in other news, installed the flush mount spoiler today. took like two minutes.
i'll try to take some better pictures once the lipkit is finished.
#552
(Mid-Atlantic)
(Mid-Atlantic)
Good luck fixing your car bro, wing looks slick
#553
#554
i was wrong about that, it wasnt the wheel catching it, but at high speeds, it couldnt hold the air pressure since my tabs were gone and there was nothing holding the sides. but now its all good, better than factory strength!
#558
finally got some time and i glued the front lip to the bumper. rear lip will be glued on tomorrow morning and after that final sanding and finishing and then paint.
also spent close to 300 on glue. i think i'll need more
