Jacobpockros’s CL-S 6-Speed Thread
#321
Dont be afraid to enjoy the car. You can take it up to redline. I go to redline probably 15 times every 30 minutes of driving.
You can fit bigger than 235 tires in the wheel wells. Ronjon has 255 without rubbing i believe. I have 235 now but want to go up to 245 or 255 for my next set.
#324
Comptech also made a strut bar for the CL-S, and I have thought about getting it but I have heard from every member on here that they didn't feel any improvements with it. One more product that Comptech made for the CLS is a front swaybar. I already have the rear one, and if I was to buy the front one, all it would do is stiffen up the front, which would give my car more understeer.
#326
Whats up with RDX owners?
RJ is running the 255/35s on his 18x8 +48mm Legends. If they cleared the BBK Id have an identical setup.
#327
Great question. I chose not to do their springs because they only drop the car 1.5 inches. Also, the majority of them are defective which causes them to rust a lot of the time. Also, Comptech never made Struts to go with their springs, and I didn't want to be riding on stock shocks with a lower drop, so the Eibach springs and struts turned out to be the much better choice, plus they match
#328
^Yup, it rubs, but only when I'm hauling ass on turns. It's such a light rub that it just sounds like your scratching a piece of wood. I will fix it once and for all though with the Eibach rear camber kit. I'm only planning on adding just enough so that it clears the wheel well lining.
Also, my Eibach drop didn't rub until I put the new wheels and tires on, because the stock wheels are 7's and the ones I have now are 7.5
#333
Boy didnt i tell you to send me you cell pix and i can clean them/enhance them up so they are easier to make out?...lol Here they are after i fixed them...
Got ride of graininess. Make sure your phone set to best settings and keeping a very steady hand helps.
I hope you didnt mind but as you see member start complaining when pix are well... crappy..lol
#337
It does have a hint more throatiness. But this is the 1st time i've ever heard anyone say the J-series motor with intake was too loud. I can get enough of hearing her x-over into vtec... Used to redline my CL-S6 any chance I could just to here those gloreous cams/valves do their work...lol. Cant wait to purchase the Takeda Intake for my TL.
#339
Nicely done sir
#340
You actually took the bumper off?
#342
Yea, I agree the bumper is easy to take off, but its not required. If you turned the wheel all the way to the left and peeled back the splash shield you can access everything.
#344
Not really, but at -2* you will have premature tire wear. It may feel better in the corners but it also may feel as though its wandering when driving in a straight line.
#346
Changing the camber on the rear wouldnt do anything to the front. But most alignment shops only do all 4 corners anyway.
#351
Stop using GD bro. damn dude. Can't wait for you to meet your maker...lol. It's obvious btw because you spoke so much about how this will elliminate the rubbing. I'm not so sure but I hope it works because id hate to waste mony on something that doesnt fix the problem...
#353
#354
Small stance + your ride height = doofy
#357
Just roll the goddamn fenders already. Its not going to degrade the value of an already cheap car.
