03 CLS Rear Lens w/ the clear trim on a 01 CLS
Is it possible to get the factory 03-CLS rear lens and stick it on a 01-CLS without any customizations?
I really like that clear/white trim at the top of the lights in the rear.
Help!
Help!
I know it's possible with the TL's, I have a friend with a 99' TL that put the 03' TL rear lens on with no problems...I haven't taken a look at the specs for the CL's but it should work...you might want to double check though.
Yes it is possible. Here are a few pics of mine http://www.thefiresauce.com/Mantis/2003-tails.htm . I bought them from http://www.autocarparts.com
Umm, there are 5 sockets on each of the tail lights. Of those 5, one doesn't fit properly. A little electrical tape will do the job just fine until I get the correct harness. Here is a pic of what I ended up doing.
Originally posted by shabzinca
I just want the lens cover w/ the white trim at the top. The housing and everything should be pretty much identical, no?
You're right, once you get the correct socket (as what I did), it will fit perfectly. You'll also need two new amber bulbs..wont cost you more then $3.
Originally posted by 23wt
I heard the socket for the lights doesn't fit perfectly and you need to tape it on or order new sockets.... that is what i found out from the general discussion area.
The socket part # is this: 33503-S3M-A11 (You will need two). You can order from your local Acura Dealer. I just installed the sockets & there were no wires to cut. All you have to do is unplug your current wiring from the old socket & plug the new socket. That's it!!! It took all of about 5 minutes...
mada51589
05-03-2022 08:54 PM
