B&M Tranny cooler installed and Transmission DIY FLUSH - detail writeup inside.
Below is a link on how to install the Tranny Cooler on your CL-S and how to do a flush of your transmission with what tools you have at home. This method does work but will take some time.
After installing it, I drove the car around for about 15 miles, and noticed that the car shifted much faster, smoother. The car seems to have really liked the new fluid, but also the help of that cooler keeping it cooler. After I got back home, that cooler was extremly hot to the touch. I tried both hoses, the top one which is the HOT in, was VERY VERY HOT, could not keep my finger on it for more than 1 sec, the bottom for at least 3 secs I could hold it on there. It was defintely working.
I hope this convinces alot of others to do this mod, because you need too. Our cars do not have a tranny cooler and the fluid just boils and most likely it causes the tranny to die. It's about a 2-4 hr project.
Enjoy guys, any questions feel free to ask.
Also Soopa, you can put this up on your site if you wish as well. So everyone can link to it, or you can just put the html on your site too, in case I take it down.
http://home.satx.rr.com/silverbullet/tranny.htm
Balla on a Budget
This looks awesome. One question though. If your tranny does die, I bet Acura is gona try to blame your tranny on this little mod dont ya think?? I think Acura will try to do anything to save them some $$$$$$$$$$!!!!!
Good Job
Good Job SilverBullet ! Excellent Write up. My Dealer told me the same thing. I made sure before I installed it. They told me it was a Preventative Maintaintence thing and that it would NOT void the warranty.
Mr. Lover-Lover
Sounds like a great little mod to have on our CL-S.......how much did it cost and where did you get it?
BTW....great instructions and pics...
Originally posted by fender4
good work/photos One question, if you mount the cooler in front of the ac condensor doesn't this affect the ac system's ability to work properly??
Originally posted by TopGum
just one question. why honda atf fluid instead of redline?
In Da LBC with Snoop Dogg
First Gen owners should contact Dustbuster4, he installed one on his car and has detailed instructions with pictures. Conduct a search here and you should find it.
I installed the B+M 70264 on my 98 3.0CL and it works great. The 70264 is about the same size as the 70255 but about 3/4 of an inch thicker. Also, the first gen 3.0cl's have a stock cooler that runs through the bottom of the radiator. So you need to put the new cooler in the return line of the stock cooler. Take the return line off, hook it up to the top of the cooler, take the other hose coming out of the cooler and hook it up to were the original return line went. I replaced my atf with mobil 1 synthetic fluid and I haven't had any problems. The cl shifts great.
ps... I was also suprised to see that the tranny drain plug is magnetic.
Curious
Has any of the transmission problems ever been addressed by Honda/Acura? Seems wierd I should go out and spend several hundred dollars of my money to prevent an overheating problem. Is this still an issue on even the latest cars?
Originally posted by SilverBullet
No, air still flows through it.
Cost Drivers!!!!
Re: Curious
Yes. Honda/Acura hasn't done anything that anybody knows of to correct the issue and so it still exists.
You need to install this tranny cooler.
Overheating......well i'm sure EricL and Scalbert can comment on this. However, i can say that the term in subjective. HOnda will tell you that the problems related to the transmission is mechanical in orgin and termination. Burnt fluid is the result of the mechnical failure. Others like EricL and Scalbert, i believe, would tell you that the tranny cooler is a must. EricL has written volumes of information regarding ATF fluid, aftermarket tranny coolor design, stock tranny cooler design and operating temperatures. Supported by data the case has been made that the tranny cooler keeps the ATF fluid MUCH cooler than what the operating temps of the ATF via the stock tranny cooler. The cooler temps should help to prevent mechanical breakdown. It's thought that the current setup allows for the ATF to over heat and breakdown. ONce the ATF fluid breaks down so does lubrication.
I aggree all cars should have a cooler, however it has not been proven heat is the cause of tranny problems. While this mod is good, I wouldn't say it solves the tranny problems.
Also I though the ATF went through the radiator for cooling. Is this not the case? Most auto cars have this setup.
Originally posted by TypeSDragoon
what would happen if we used two coolers? one to cool it down even more before it went back to the tranny..
Like I said, too COLD is bad for the tranny. It will not operate at prime temperature and your tranny could go out sooner.
yes but now that air is heated to over 180 or maybe close to 250 degrees, the ac system is designed for a lot less for proper heat exchange. The ac will work it's just something to be aware of on a very hot day.
Our cars do not have a cooler, most cars do, but Honda/Acura did not put one on ours.
Heat always causes Tranny problems. Heat is what kills auto tranmissions.
on bin laden
Use redline on a Honda tranny and your asking for trouble. Honda trannies are real picky on what you put in them.
Originally posted by fbazakos
nice write up ... but comptech recommends redline atf ... we need to look into this recommendation more ...
Obviously they know more about the Honda tranny than Comptech.
Subie Dubie
Just to let you know, Redline, Mobil 1, Amsoil all recommend to stay with Honda ATF Z1.
Originally posted by Red Rider
Well if Comptech recommends Redline to be installed with the cooler if you do their Supercharger i imagine they have a reason.
The oil manufactures will know much better than Comptech.
Request/Comments:
1.I would hope that all of you guys that have done the tranny cooler upgrade would update us from time-to-time on your impressions – whatever, they are… (Please comment in the tranmission problems forum -- OK?)
2. We have "cooler"/"warmer" -- IMO, it's less than adequate. If you feel differently, that's ok with me... Perhaps Honda/Acura will publish specs. and support an external buss one day to allow sensors (ATF fluid cooler temp, and so on) to be integrated into the Navi for "weenie" purposes (ok, kill that dream for now)...
3. As far as the heating relative to the AC, who knows. A temperature reading before and after would be helpful...
4. I'm definitely going to link this in via the tranny forum.
5. As for the Redline -- I talked to them and they were more inclined to suggest that it was a no-brainer when "racing" was mentioned. When I talked to Mike B, they had been running the High Temp stuff for around a year with no problems... So, it doesn't cause immediate destruction...
Originally posted by typeR
none of them contain Z1 and they are just covering there ass...i talked with a redline tech and asked him hypothetically warranty aside ...he said our car would benefit from redline fluid and i even told him i wanted firmer quicker shifts and would redline race a type F fluid help he said yes....
Thanks for the installation instructions. Very cool.
I am going in tomorrow to get a few things fixed on my car and get the tranny fluid flushed, but also to get my tech's opinion on whether or not the tranny should just be replaced and put the cooler on a new one. We'll see.
I talked to a friend, an Acura Master certified mechanic who has worked for Acura dealership over 10 years...and this is what he had to say about installing the transmission cooler:
Well,
It definitely would not hurt, but its not just heat that kills them, its the fact that Acura is trying so hard to make the shifts so soft that by doing so it wears the clutches out and then all the friction material gets into the tiny orifices in the valve bodies and causes them to fail. (to make a tranny shift very smooth/soft, you must slip the clutch packs on each of the gears to the point that they literally eat them selves up... this also causes a tremendous amount of heat in the fluid which causes it to break down as well as carrying the heat to the rest of the parts which causes them to fail prematurely too!)
Have you ever been in a 91-92 Legend? If so you know how hard they shifted, especially in the lower gears? Well this is why the trannies hardly every had any problems! (A hard shift is done by slamming the clutches together with high fluid pressure and a very small if any accumulator/dampener spring!)
The 2002 CL and TL have what is called a fluid warmer! (what this actually does is help the fluid warm up to operating temp by passing engine coolant through a heat exchanger, Also it helps cool the fluid and maintain a constant temp around 180-200F) So if you install an external cooler in front of the radiator, this MAY give you problems with warranty issues if it ever comes up (which it will!) My suggestion is go see Bob, he is the tranny expert, and more up to date with those trannies!
Well,
Well,
Well,
Well,
Well,
those suckers shifted hard and i think the legends were infamous for the hard shifting
WHAT I DONT UNDERSTAND IS THIS
have yall rode in a toyota or a ford crown victoria or in a chevy suburban
well ive driven all these cars recently and it surprises me how smooth the transmissions are. I DONT UNDERSTAND HONDA they have been making cars long enough
why cant they get this freakin transmission shift smoother???????
at times i just get tired of feeling the shifts in an automatic.
sidemarker
Well,
Well,
The shifts, at least for my taste, could be tightened-up. There was talk (once upon a time) that Level-10 was going to make a controllor. The shift solenoids do allow for a variable transition between the “ON” and “OFF” (Think of it as being able to adjust the ramp time). I can think of some related issues: 1) Too hard could be just as bad as energy needs to be absorbed (there are a lot of clutch packs spinning around in a number of different gears and they need a bit of time to start and stop. 2) The clutches also don’t “enjoy” extreme temperatures as it can cause varnish to just make the clutches that much more “slick” and make for even more heating (and the damage just gets worse – ever checked out a slipping clutch or a clutch that is just starting to slip on a manual tranny)?
RE: The 91 Legend – interesting that a close relative has around 150K on the car and the tranny is “problem free”. And, the car gets a pretty good workout (part-time brutality).
There seems to be so much confusion about the warmer. IN fact, there is a small “error” in the DIY Install FAQ that reports that the car has no cooler. Here is the exact quote from the DIY page/article:
“Make note that the CL-S does not have a STOCK tranny cooler at all. We must install one. If it had one we would just install next to the stock one so both are being used. Much easier install.
The 2001 CL Service manual has two notation about this being a cooler and a warmer. IMO, I don’t want ice cold ATF running around in my tranny. The tranny blurbs recommend 175-200 degrees for ATF (YMMV).
I have no doubt, based on previous member comments, that some dealer or other “agent” will “go for the cooler” as a problem. However, there are people that are getting in “trouble” with getting actuators replaced by just showing up with an AEM or some lowering springs.
Re: B&M Tranny cooler installed and Transmission DIY FLUSH - detail writeup inside.
Makes sense. But the fluid gets very hot to where the cooler comes in handy. Most cars have a external stock cooler, ours doesn't. We have that warmer/cooler but its not as effective as a regular cooler. I needed to get a tranny cooler since I will be towing a 1200lb waverunner.
The tranny fluid will not be COLD, it will be still hot but help prevent it from getting seriously hot. The bigger the cooler the colder it gets. Mine is the smallest you can get which is all I needed.
