98 2.3 Dyno #2 212hp
A-CL Totaled Member
Originally Posted by ju5tchi11in
since no one checks here... good job in this thread too
Originally Posted by CLS2001_97124
Nice numbers!
Is the torque suppose to be so low at low RPM? and I think this is the first graph I've seen that has Max torque occuring after Max HP has been reached.
very nice. maybe need a tad more tuning as you're torque curve jumps around so damn much. AS i've said in the other threax very nice.
Also very funny seing you have 75 hp at 2500 rpms then having almost 200 hp only 1000 rpms later. good stuff.
A-CL Totaled Member
Originally Posted by Black CL-S 4-Life
Nice numbers. What kinda times are you expecting at the track??
A-CL Totaled Member
Originally Posted by allmotor_2000
Nice
Did you use a H23A kit or make a custom one?
A-CL Totaled Member
Originally Posted by mrsteve
Just as fast, if not faster than a stock automatic CL-S... looking nice man. It's a sleeper
how much did it all cost you? never track mine more hwy racer, i went cai,headers,2.5 piping,afvc,zex dry kit never got her tune ran me $900, but i have the david banner complex too many evo and wrx's around undergoing gamma ray treatmeant i went H"ard"22 next treatment turbo so i was wondering what a kit would cost?
A-CL Totaled Member
There are so many options when putting together a kit. My setup ended up being about 3500. Had a I bought a standard premade kit, I would not be able to run 11psi as safely and reliably. Honda tech is the best resource I have found as far as turbo info goes.
A-CL Totaled Member
Originally Posted by Cocoa
hey, did you just dyno it, or retune it? If you havent tuned your car, I suggest you do so, you'll gain more hp that way...
Thanks for the tip, although thats kind of a no brainer. The graph was printed at the end of a tuning session, not the best tuner but it is tuned.
A-CL Totaled Member
What was your 60' time?
I'm pissed I couldn't make it tonight
I only made 5 runs since I only stayed for an hour. The rest of the info from the best run :
R/T .810
60' 2.294
330 6.318
1/8 9.605
MPH 76.53
1000 12.365
1/4 14.700
MPH 97.26
The thing that made the biggest improvement over last time was shifting at lower RPMs and using 4th gear across the line. The launch and the 3-4 shift seemed to have the biggest impacts on my times. When I got better reaction times I got slower 60' times because I would give it too much gas and get wheel spin/hop. Working on the launch is definately crucial. Next time I go back I will probably have a drop and an electronic boost controller, still shooting for the 14.5. Im pretty sure the car could do it now if I practiced more.
A-CL Totaled Member
Originally Posted by shineynitelite
well he shaved a good 2 seconds off with 10psi... good work.. any internal mods?
Originally Posted by CiLver2.3
Nice HP #'s and nice track times. I believe your 14.70 makes you the quickest I4 CL on the board.
Originally Posted by xrunner86x
thanks. no internals, figured for the f23 custom internals werent worth it, especially since a new f23 can be had for about 400$.
I had always wanted to boost my Accord but never had the chance and regular bolt ons do little for the F23 motor.
D-Rob
62
Jan 5, 2016 11:44 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
