Yokohama es100 highspeed review
Cost Drivers!!!!
WOW.....i had a "friend" who has the tires on his car and he did a few high speed runs last night. My "friend" doesn't have any suspension mods aside from sway bars. DANG..... he says the car feels absolutely PLANTED. No jumpiness at all. He says he went up to 120....redlined 4th gear. He says his pretty impressed and the stability is likely due to the wider tire and rims. 235 + 8 inch wide rim.
Censored User
Location: Miami - just one day, I would like to drive without getting cut off!
"friend"
did your "friend" happen to try out any twisties? If so how fast and how did the tires do?
Cost Drivers!!!!
Originally posted by JaDia4
"friend"
"friend"
My "friend" did try them on twisties and they are fantastic. My "friend" will be putting out a video detailing his review of the tires soon.
Very flat cornering. No sidewall flex. Grip is nice. You can really push the tires and they respond. Of course my "friend" has a 6speed CLS with HLSD which in conjunction with the tires allows him to push it a little more than the average CLS.
Cost Drivers!!!!
Originally posted by civic4982
I did right up to around 150 on the stockies... going straight is easy on most tires.
It's not the same by any stretch of the imaginenation. The car feels skitesh with stock setup.
Cost Drivers!!!!
Originally posted by darrinb
your friend sounds like you
i'm debating to go with the yoko es100's or kumho 712's
yokos own me......
Cost Drivers!!!!
on btw zapata, are u waitin for the return of sadam and osama to drop your car, get some springs already
Yea i know needs to be done......car looks like a friggin 4x4 with my current setup. Did the spring thing once....want to do a coilover system. Next year.
Cost Drivers!!!!
i'd say give it a nice rake w/ some teins, 2.25 inch drop in front and 1.75 in back
Will definitely rock the teinSS.
Censored User
btw- since both you and your "friend" have es100's maybe the both of you could give your opinion on the road noise compared to the stock tires?
Cost Drivers!!!!
Road noise is present. Something my "friend" had to get used to. But I also think it depends on the size of the tire you get. My "friend" has the 235 tire. He says it bothers him somedays but others it doesn't. The trade off is worth it in ihho.
OH also, he has also noted improvement in braking. MUCH better.
Ask your "friend" if the tires give some warning before they break loose completely under heavy corning. The stockies will squeal before the car breaks loose, but then again, the stockies squeal all the time. I like a little warning to let me know I'm at the limit.
I've got yokos on my vw bus, my brother has 'em on his tbird (IIRC he's running the Avids), and when I wear the stockies out, I think I'll go w/ the es100's.
I think the ES100s are a pretty decent tire. I had them on the track and they were pretty predictable at the limit, but when you really warmed them up, they lost grip. If you are looking for maximum grip, go with Kuhmo MX's or S03's.
And BTW.....They do squel quite a bit at the limit.
Cost Drivers!!!!
My "friend" says yes they do warn you before they break. They are quiet so when you hear the squeal you know it's because you are on them
Cost Drivers!!!!
My "friend" says the same.
I have these tires as well,..on stock wheels however. They are quite pleasant. Definitely better grip on turns. Everything feels more stable. However, I'm dropped on Eibach Pro-kit,.. ride still feels harsh on cracked roads.
Does anyone know if Koni yellows will improve the road feel.. I hate the vibrations from the road.
Originally posted by Zapata
yea, S03s seem VERY nice but the price tag is a bit steap
Cost Drivers!!!!
My brother has them on his M3. They are very sticky and wear well for the type of tire it is. I would personally try Kuhmo MX's. They are fairly comparable to S03's, but cost a substanial amount less. Grassroot's Motorsports did a test of KD's, MX's, and S03's and it was pretty impressive how well the MX's did.
interesting.....some people said the MXs are on the heavy side and so that's why i didn't get them. Although with a 235 tire i don't know how light of a tire was hoping to get anyway
Spectacular Aroma About
Cost Drivers!!!!
Originally posted by ChadT
I actually checked the weight of the Kumho MX against the Toyo T1s which is suposed to be a light tire. The Kumhos are only 0.2 lbs heavier in a 235/45/17. Funny these would be mentioned I have a set on the way to my house right now Along with a set of SSR Comps from the tire rack. I didn't want to look just like Zapata's so I'm going for anthracite on anthracite. I saw the anthracite comps on a dark grey (anthracite) M3 and it looked killer. I'll try to get some pics but I will be without center caps until November. Will also give a full report on the MXes. They are a sweet looking tire. $10 more than the ES 100s.
Bah the car looks awesome. Only reason i haven't posted pics is my car looks like CRAP....haven't washed/detailed in a while. I hoping this sunday I will get some time.
that light huh? hmmmmmm very nice gives me a nice option. How do the Khumos wear?
joflewbyu2
08-18-2019 10:38 PM
ITSJESTER
17
12-06-2018 02:29 AM
flyromeo3
09-24-2015 11:24 PM
