Easy steps for changing the Engine Oil/filter
Old Sep 21, 2003 | 09:44 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Easy steps for changing the Engine Oil/filter:
Consumables you need:
1) New Engine Oil. I recommend Mobil 1 SuperSyn 5w30. 5 Qrts for like $18.88 at your nearest walmart. The CLS engine needs 4.6 Qrts when changing oil and filer. Keep the rest to top it off if the oil level gets low.
2) New Engine filter. I recommend Mobil 1 M-104 or Purolator PureOne PL14459.
3) New Drain plug washers from your dealer (for 20 cents each).
Tools you need:
1) a ratchet with 14mm socket. a 14mm closed wrench will work just fine too.
2) An Oil Funnel ( cost less $2)
3) A used Oil Container ( 6 qrts goes for like $4.99)
4) A Oil filter wrench ( goes for like $3.99)
5) A good set of 2 ramps.
Instructions:
1) Warm up your CLS for like 5 minutes.
2) Drive your CLS slowly over the ramps.
3) Shut off the engine.
4) Open the hood.
5) open the Oil filing cap
6) get under your car, Locate the engine oil drain plugs at the bottom of the Oil pan. (It is pointing to the back). Use the ratchet to loosen the plug. Position the Used Oil container to catch the spilled engine oil. Remove the Oil Drain plug. Reposition the container to catch the spilled engine oil.
7) Wait till engine oil is drained.
8) While waiting the oil to get drained. Use the Oil filter wrench and remove the oil filter.
9) Replace the filter with a new one. Lube the new filter's gasket with clean oil before screwing it on. Screw the new filter in hand-tight, then use the filter wrench to screw it another 3/4 turn, and no more than that.
10) Wipe the area around the Oil filter where the the oil has spilled with clean paper towel.
11)Back to Oil Drain Plug. Wipe the bottom of the oil pain. Replace the old crush washer with a new one. Replace the oil drain plug and hand torque it! Use the ratchet it to torque it a bit more like 1/4 of turn and no more.
12) Wipe the bottom of the oil pain again.
13) Use the Oil funnel and Fill 4.6 Qrts of the new oil.
14) Replace the Oil filling Cap.
15) Get the car off the ramps.
16) Keep the engine running for 5 minutes. Shut off the engine
17) Check the Oil level by looking at the dipstick.
18) Check for any leaks.
19) Remove the Used Oil Container and ramps, and tools and you are done.
All what you have to do now, is to go properly dispose the used engine oil and filrer by dumping it any collecting Auto Center. It is FREE!
Nashua.
Note: I posted this in the ramblings, I felt is also appropriate to post it here too
Old Sep 21, 2003 | 09:48 PM
darrinb's Avatar
///M POWER
we should make this a sticky in the useful topics..
Old Sep 21, 2003 | 09:53 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
nash: I dind't know not many ppl knew about tha 18.88 deal for Mobil 1 5 quart jugs. It's a steal considering they're usually about $5 a quart.
Also, I've been using the M1-105 and it's worked out great. More size = better in my book ...
this should be stickied
Old Sep 21, 2003 | 09:55 PM
darrinb's Avatar
///M POWER
where do u guys get the m1 filters??
i also get the five quart jugs for 18.88, but one time i went and they didnt have any 5 qrt jugs i had to buy a case of 6 qrts for 29 dollars
Old Sep 21, 2003 | 09:59 PM
zigzagzig's Avatar
what do you use to catch the used oil, and where can you buy it if at all, locally? also, the ramps, what do they look like, and are they safe enough to hold the car? any links/pics?
Old Sep 21, 2003 | 10:00 PM
zigzagzig's Avatar
and where in god's name do you guys get the mobil1 syn, for 18.88? i looked everywhere
Old Sep 21, 2003 | 10:05 PM
darrinb's Avatar
///M POWER
5qrt jugs at walmart for 18.88, just enough for an oil change
once you buy 12 five qrt jugs you'll have enough left over oil to do a oil change w/o buying more oil
Old Sep 21, 2003 | 10:40 PM
civic4982's Avatar
you can get the M1-104 or M1-105 at any Autozone retailer.
Old Sep 21, 2003 | 10:52 PM
darrinb's Avatar
///M POWER
whats the diff between 104 and 105
Old Sep 22, 2003 | 11:05 AM
Manic's Avatar
1.
Just kidding, I beleive it's volume, 105 being "bigger or having more capacity. I don't know if the filter element/material is the same or not.
Old Sep 22, 2003 | 11:11 AM
Red-CL's Avatar
Doin' da crack shuffle
My cousin buys it from Walmart.
Old Sep 22, 2003 | 11:15 AM
Red-CL's Avatar
Re: Easy steps for changing the Engine Oil/filter
I do these exact steps but always end up with too much oil. I'll even let it drain for about ten minutes.
Old Sep 22, 2003 | 03:54 PM
Happy CL-S Pilot
Oil filters:
Stock Size:
1) Pureolator PureOne: PL14459
2) Mobil One: M-104
Oversized Size (just more filter media and the by-pass valve works at higher PSI):
1) Pureolator PureOne: PL24458
2) Mobil One: M-105
You can also cross reference those filters if you like STP. FRAM etc....
Nashua.
Old Sep 22, 2003 | 04:20 PM
beerknurd's Avatar
Busy Living
i thought it was maintance free till 100k miles... that doesn't include oil?
Old Sep 22, 2003 | 05:50 PM
ChadT's Avatar
Spectacular Aroma About
Nice post Nashua. I think my car has a 17mm drain plug though. It's an '03 6 speed. (on her 2nd fill of M1 5w30)
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Aleax
Sep 11, 2015 11:31 AM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
