wtk having problem
Old Jan 27, 2011 | 12:54 PM
ivan06106's Avatar
wtk having problem
hey this morning i started the car an the rpm started going up an down between 0 an 1500 an i really don't know what's the reason for this any suggestion...
Old Jan 27, 2011 | 01:00 PM
ivan06106's Avatar
its an 03 cl s 6 m/t
Old Jan 27, 2011 | 01:12 PM
tnobori1's Avatar
Missing my
Happened to me a couple years ago. Did it do it whenever you came to a stop, too? I believe I replaced my battery (for another reason) and it stopped doing it. Seems weird, but it worked.
Old Jan 27, 2011 | 01:22 PM
ivan06106's Avatar
yeah i was thinking bout the same thing ill probably go replace tomorrow thanks
Old Jan 27, 2011 | 02:11 PM
tnobori1's Avatar
Missing my
No worries!
Old Jan 27, 2011 | 02:24 PM
aznboi2424's Avatar
I say vac leak or IACV.
Old Jan 28, 2011 | 04:58 AM
Rajca's Avatar
wham bam thank you ma'am
vacuum leak. check for any loose vacuum hoses. also any cracked or cut hoses. worst case it can be the iacv
Old Jan 28, 2011 | 07:32 AM
fuzzy02CLS's Avatar
Idle Air control valve.
It's either dirty & sticking, or needs replacement. If it's never been replaced, it's time.
Old Jan 28, 2011 | 12:29 PM
ivan06106's Avatar
yeah but only does it like once in a while but wen it does it, it only happens wen im starting the car in the morning
Old Feb 13, 2011 | 10:48 PM
ivan06106's Avatar
what should i used to clean the IACV ?
Old Feb 14, 2011 | 12:09 AM
civicdrivr's Avatar
Carb cleaner.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
