World's First Auto CL-S Turbo - Finished!
Old 09-03-2005, 04:43 AM
  #201
ThinJim's Avatar
Originally Posted by mclarenf3387
I'm curious what all the sandrails using the J32/35 blocks are using for trannies. They can't be using stock ones at 1000hp that some of them run. Are they using adaptor plates to run GM 4 speeds? or are they using 6 speeds? I'm curious how they are putting down the power.
They use a transmission specific for sandrail applications with the use of an adapter to mount that transmission to the j32/35 block. Their trannys are similar to that of a early volkswagan transaxle setup, only stronger.
Old 09-03-2005, 01:08 PM
  #202
nothing
bryanz3.0cl's Avatar
Originally Posted by allmotor_2000
From what I know, the Dr. Evil tranny cannot hold up over 350whp.
whoever the av6 guy is that comes on here already has 320whp before the 3.5 swap, so we'll see how it holds up after he gets tuned and all is said and done.
Old 09-03-2005, 05:40 PM
  #203
mrsteve's Avatar
Yes and his Dr. Evil transmission was slipping with 320whp
Old 09-03-2005, 07:23 PM
  #204
318whp/289wtq @ 6psi
blk2001tlon19s's Avatar
That's true but I believe it was a one time thing and hasn't happened since but I could be wrong.
Old 09-03-2005, 09:02 PM
  #205
ghost_masterCL's Avatar
It turns out it wasn't slipping, it was just accelerating too fast for the ECU to compensate, and the ecu couldn't tell the transmission to shift fast enough before it hit the rev limiter. It was all the ECU, not the tranny.
Old 09-03-2005, 10:50 PM
  #206
mrsteve's Avatar
It hasn't happened since because the transmission was sent back for a rebuild
Old 09-03-2005, 10:57 PM
  #207
That's cool. Didn't recall that happening though.
Old 09-04-2005, 11:18 PM
  #208
it wasn't rebuilt. he took it in and they said it was fine physically, but that the ecu wasn't sending the "shift" signal fast enough.
Old 09-06-2005, 10:34 AM
  #209
563hp daily
02AV6's Avatar
WHOA! There is so much misinformation with Dr. Evil, so despite my short vacation I need to correct it.
Notwithstanding the fact that Dr. Evil was asked to deliver a reliable AV6 transmission to support up to 500HP or 390WHP (22% drivetrain loss), nobody at that level yet to judge the product , however my previous 321WHP AV6 record proved it holds the power just fine both roll and from the line. In fact, the shop mentioned they can upgrade to over 390whp if one desires . As far drive train loss, they believe it should be pretty much the same as stock but significantly better quality, more efficient/reliable along with help of LSD.
Now, my reported track issues with Dr. Evil actually turned out to be ECU and electric malfunctions, specifically hitting rev limiter, yet my 225/45/17 tires made an influence by rotating 832 rev per mile vs. 806 reported on stock 205/60/16 shoes. So, no my Dr. Evil was never rebuilt and it's a sure keeper. ECU is weak and non-reprogramable, but that's another subject.
Soon, will share my new DYNO results with 3.5L swap, EU tuning (fingers crossed),and once I feel the car track ready, going to get 245/45/17 DR which are close to stockers in terms of rotation specs. And while I don't expect to reach the above mentioned 390WHP to judge whether or not Dr. Evil mission has been accomplished , still have a full confidence in their product along with another advantage by being local.
Finally, if anyone with 5AT NA or FI J32 wants a truly reliable transmission, send or bring your auto tragic to their door. Level10, and number of others have tried and failed while Dr. Evil mission has been nothing but success for both AV6 and CL 3.0, hence my project continued.
Hope it helps.
Old 09-06-2005, 11:34 AM
  #210
563hp daily
02AV6's Avatar
And any DYNO results from auto turbo yet?
Old 09-06-2005, 12:07 PM
  #211
^^ yeah I was thinking the same thing serge, WE NEED A DYNO.
I guess I learned somethign about teh dr evil tranny. thought there was a "upgraded tq converter" in there, but at least I was right about the ecu being the problem .
Old 09-06-2005, 02:20 PM
  #212
Registered Type-S Owner
congo's Avatar
Nice Ride~~
BTW you gotta take out the bulbs inside the road lamp housing (so do i )
Old 09-07-2005, 12:46 AM
  #213
563hp daily
02AV6's Avatar
Correct, TC was rebuilt by some company in Arizona I forget, and correct again regarding ECU issues.
Pham Alvan
05-18-2021 06:48 AM
RLX-Sport Hybrid
3G RLX (2013+)
27
12-07-2018 12:11 PM
blacktsxwagon
10-27-2015 10:12 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: World's First Auto CL-S Turbo - Finished!
