Winter Gas
Old Dec 3, 2002 | 07:28 AM
EdgarFanCLS's Avatar
Masshole
Winter Gas
Can someone here explain the differences between "winter blend" gas as opposed to summer? I've heard that the two are different, but I wasn't turning up very useful information when I did an internet search.
Also, would the winter gas cause my MPG to drop by about 2? During the summer I was probably averaging around 27 MPG, and now I'm down to around 24-25. Same commute, driving habits, etc.
Old Dec 3, 2002 | 07:44 AM
NSXNEXT's Avatar
Winter gas contains a higher level of MTBE. MTBE (methyl tertiary-butyl ether) is a chemical compound that is manufactured through the chemical reaction of methanol and isobutylene. MTBE is produced in very large quantities (over 200,000 barrels per day in the U.S. in 1999) and is almost exclusively used as a fuel additive in motor gasoline. It is one of a group of chemicals commonly known as "oxygenates" because they raise the oxygen content of gasoline. At room temperature, MTBE is a volatile, flammable and colorless liquid that dissolves rather easily in water.
MTBE has been used in U.S. gasoline at low levels since 1979 to replace lead as an octane enhancer (helps prevent the engine from "knocking"). Since 1992, MTBE has been used at higher concentrations in some gasoline to fulfill the oxygenate requirements set by Congress in the 1990 Clean Air Act Amendments. (A few cities, such as Denver, used oxygenates (MTBE) at higher concentrations during the wintertime in the late 1980's.)
Old Dec 3, 2002 | 07:57 AM
Scooter's Avatar
'Cooter
too bad the damage has already been done...once MTBE gets into the water supply, it spreads rapidly, and it cannot b destroyed by chlorine or other chemicals...there was a 60 Minutes on this bout a year ago...they cited towns that used MTBE and how a rare cancer was diagnosed due to MTBE in the water supply...i believe MTBE is being phased out and replaced by natural oxygenates such as soybean or corn
also, the 60 Minutes program showed how the use of MTBE did NOT reduce emissions by vehicles nearly as much as was intended
Old Dec 3, 2002 | 08:27 AM
CO-CL-S's Avatar
You can expect a 10-15% hit in gas mileage with an oxygenated fuel.. YMMV
Old Dec 3, 2002 | 08:39 AM
Masshole
That seems about right with what I've been getting lately. Do all of the colder regions switch to oxygenated fuel in the winter-time? And what are it's advantages in colder weather?
Old Dec 3, 2002 | 08:50 AM
IntegraVT's Avatar
Stealthy A-CL Member
This link might help...
http://www.epa.gov/otaq/oxygenate.htm
Old Dec 3, 2002 | 09:39 AM
fuggedaboutid's Avatar
Yes SIR.
Toronto , it's about -10C or about 25-30F. I consumed half a tank of fuel in no time yesterday (
Old Dec 3, 2002 | 12:41 PM
gmilian's Avatar
Red X
i use 76 gas. no mtbe whatsoever. and i get aprox 22mpg with like 85% freeway driving
Old Dec 3, 2002 | 05:57 PM
Johnny Rad's Avatar
NSXNEXT - say hey to Jaws!
Old Dec 3, 2002 | 06:19 PM
Wires's Avatar
Pure gasoline won't burn below -44C (flash point of gasoline). If they don't add to the fuel, then your car won't start when it's really cold.
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
jmaxima03
Sep 27, 2015 10:22 AM
