Windshield Washer Sprayers?
ok so i got my car and the washer sprayers didnt work. i just got some from acura today! im going to put them in after work. question is.... when i messed with them a while back i found a spring and a ball and broken white plastic??? so i assume check valve.......im replacing them to solve this, but how can i get the gunk thats built up in my washer tank out since i never used it in 2 years.... has anyone had this problem????
I guess you could just take the tank off and run some cleaning agent through it and rinse it out with some hot water.
ya my sprayers were clogged and i went to clean them and the check valves fell apart. so i have to replace them. got the hose off on my lunch break and emptied the tank by just letting the pump suck it out. and it had all kinds of green goop and nasty colored crap in it. i have to take the hood liner off and disassemble the sprayer things.... pain in the ass im takn pics for a DIY sorta thing. also to show the pain....
this job was a pain... hard lines, its freezing cold, dirt, broken clips.... and missing parts....
the check valves are missing??? they rotted off. oh and the best part is......... i broke every clip holing the hood insulation on.....and the piece under the spayers (the cover thingy)
have to go get new ones now.....
dont recommend doing this ever again....
Wow these systems are a PITA. My last vehicle wasn't holding fluid and appeared to be leaking from the reservoir so I go out and buy a new one. Lo and behold when I go to replace it the tank was fine; battery acid had leaked onto the pump causing it to basically melt.
Good luck..
Good luck..
Yeah mine was clogged a long time ago, and I had to take off the hood liner along with those damn plastic clips I ended up gashing my hand up pretty bad with some pliers...
Anyways, I just took out the white plastic piece connecting the tube to the spray spout, cleaned that out with a small brush I had, and it was working as good as new
I broke a few of those clips when I was cleaning out my sprayer hoses, they didnt work when I bought the car, it was a weak spray.
Turned out there was some junk in the lines, just blew it out and it works.
you can take the washer tank out and clean it that way. you'll have to take the front bumper off.
My tank is just empty right now cause I never use washer fluid anyways so I emptied it. plus its shaved off weight lol
i broke all but 1 clip for the hood liner..... next i have to go buy the pieces that go under the sprayers the black plastic hose covers.... i broke those bitches off.... lol
and as for weight i leave it and if im losing ill spray it all for the win!!!!!! NOT
Ok the list of things u will need.
-10 clips to hold the liner in.
-u will need the plastic covers for the sprayers since they dont come off either.
-new line for the washer fluid
and tools- clipe remover or needle nose, box cutter, and philips head thats it.
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
