Windshield Washer Sprayers?
Old Feb 17, 2010 | 08:43 AM
Nicks01CL-S's Avatar
"DD" Designated Drinker
ok so i got my car and the washer sprayers didnt work. i just got some from acura today! im going to put them in after work. question is.... when i messed with them a while back i found a spring and a ball and broken white plastic??? so i assume check valve.......im replacing them to solve this, but how can i get the gunk thats built up in my washer tank out since i never used it in 2 years.... has anyone had this problem????
Old Feb 17, 2010 | 09:11 AM
pits200's Avatar
Replace it, I don't think it would be that much of an issue and probably can't cost more than $30 I'm guessing but I could be way off base.
Old Feb 17, 2010 | 09:24 AM
the check valves were 6.75 each so not too bad but the lines are rock hard and u have to pull the hood liner.
Old Feb 17, 2010 | 09:30 AM
SG81's Avatar
Missing My CL-S
one of mine stopped working too. i think it may be clogged
Old Feb 17, 2010 | 09:43 AM
pits200's Avatar
I thought you were talking about how to clean the fluid tank. I was saying to just replace that. But wow, I just looked online and saw that the whole tank set costs $100 forget that idea.
I guess you could just take the tank off and run some cleaning agent through it and rinse it out with some hot water.
Old Feb 17, 2010 | 11:12 AM
ya my sprayers were clogged and i went to clean them and the check valves fell apart. so i have to replace them. got the hose off on my lunch break and emptied the tank by just letting the pump suck it out. and it had all kinds of green goop and nasty colored crap in it. i have to take the hood liner off and disassemble the sprayer things.... pain in the ass im takn pics for a DIY sorta thing. also to show the pain....
Old Feb 17, 2010 | 04:00 PM
this job was a pain... hard lines, its freezing cold, dirt, broken clips.... and missing parts....
the check valves are missing??? they rotted off. oh and the best part is......... i broke every clip holing the hood insulation on.....and the piece under the spayers (the cover thingy)
have to go get new ones now.....
dont recommend doing this ever again....
Old Feb 17, 2010 | 06:06 PM
civicdrivr's Avatar
Yea, most of those parts are one use only.
Old Feb 17, 2010 | 06:20 PM
CollinCL's Avatar
Wow these systems are a PITA. My last vehicle wasn't holding fluid and appeared to be leaking from the reservoir so I go out and buy a new one. Lo and behold when I go to replace it the tank was fine; battery acid had leaked onto the pump causing it to basically melt.
Good luck..
Old Feb 17, 2010 | 07:39 PM
Rapture's Avatar
Yeah mine was clogged a long time ago, and I had to take off the hood liner along with those damn plastic clips I ended up gashing my hand up pretty bad with some pliers...
Anyways, I just took out the white plastic piece connecting the tube to the spray spout, cleaned that out with a small brush I had, and it was working as good as new
Old Feb 17, 2010 | 10:57 PM
aznboi2424's Avatar
I broke a few of those clips when I was cleaning out my sprayer hoses, they didnt work when I bought the car, it was a weak spray.
Turned out there was some junk in the lines, just blew it out and it works.
you can take the washer tank out and clean it that way. you'll have to take the front bumper off.
My tank is just empty right now cause I never use washer fluid anyways so I emptied it. plus its shaved off weight lol
Old Feb 18, 2010 | 12:23 AM
i broke all but 1 clip for the hood liner..... next i have to go buy the pieces that go under the sprayers the black plastic hose covers.... i broke those bitches off.... lol
and as for weight i leave it and if im losing ill spray it all for the win!!!!!! NOT
Old Feb 18, 2010 | 08:52 AM
SG81's Avatar
Missing My CL-S
nice pics Nick. i'm going to attempt mine soon, just waiting for it to warm up a bit. maybe i'll buy some clips ahead of time just in case
Old Feb 18, 2010 | 11:22 AM
Ok the list of things u will need.
-10 clips to hold the liner in.
-u will need the plastic covers for the sprayers since they dont come off either.
-new line for the washer fluid
and tools- clipe remover or needle nose, box cutter, and philips head thats it.
TheMuffinMan
Jun 2, 2022 07:11 AM
bluetl04
Aug 16, 2016 02:49 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rhdune16
Sep 28, 2015 11:31 AM
Cexarin
Sep 23, 2015 07:43 PM
