Window regulator replacement for '03 CL-S
Black is a ***** to Clean
1 Post
Pass. side window fell down inside door last night ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
Dealer doesn't even have the part in stock and wants to charge a crapload. Anyone know who might be able to do it for cheap or if I buy the part online, can offer a good deal for the labor. I mind wind up doing it myself, but I thought I'd ask. I'm in North Hollywood, thanks
Whats up with RDX owners?
Its an $80 part. Print out the quote from AcuraOEMParts or any of the other parts websites and have them (or any dealer) price match. Its a simple install too.
Thats not a complete part number.
The part number for the window regulators are:
Driver side - 72250-S3M-A12
Passenger side - 72210-S3M-A12
it's very self explanatory when you pull the door panel and look at it. unbolt the old from the door fram and window. bolt in the new one to the door frame and window plug in switch. it's really that simple.
I just replaced mine... real easy DIY, the new part even brings 3 screws (half way in)... leve them on, you will notice that they go in through special shape holes making it even easier to install. New part comes in half way up position (for the glass) so the two screws holding the actual window are aligned with two holes in door to get socket/rachet through... you dont even have to take out speaker. All you will need is phillips screw driver and 10 mm socket with extension and ratchet (a 10mm wrench can also help)... some common sense also required (just a little). Believe it or not, I was carrying new part on passsengers side floor, had not time to replace, had tools ready (too much work at the office)... I got stuck in traffic and did replacement while sitting in the jam. Re instaling was under 20 minutes... dis assembling maybe 10. This car is really designed for DIY (oil changes, filters, most maintenance really easy for anybody up to it and this site is the best: people here explain everything very clear and have patience with us newbies). All the best from Panama.
![what](https://acurazine.com/forums/images/smilies/what.gif)
How much traffic do you get down there?
TLDude876
12-28-2016 03:18 PM
NBP_BALLER
09-23-2015 08:18 PM
ahsm
09-09-2015 08:35 AM
asahrts
09-04-2015 05:55 PM
