Will These FIt???
Old Oct 23, 2001 | 05:23 PM
xxy1xx's Avatar
kwikCLvr
Will These FIt???
Will 18x7.5 Giovanna Kobe wheels fit the 3.2CL-P without rubbing??? and if i get them what size tire should/do i need to get??? thanks alot......here's a link to the wheels--> http://www.wheelmax.com/Wheels/Giovanna/kobe.gif
P.S. i'm mostly likely gunna get them in chrome...ne thoughts???
Old Oct 23, 2001 | 05:26 PM
Z's Avatar
Z
Just make sure you get the right offset.......more than 35mm
then you should be fine........get the 19x7.5--that would be killer
Old Oct 23, 2001 | 05:29 PM
xxy1xx's Avatar
kwikCLvr
I'm getting a deal on the 18's...i would go higher but i've heard that leads to many troubles
Old Oct 23, 2001 | 05:38 PM
4thGSi's Avatar
STi
42 offset is the lowest you can go for our CL-S , anything lower that offset is a no no; especially when you drop the car it will cause major rubbing. So 42 up is fine for the CL-S...
emailnatec
29
Sep 28, 2018 04:27 PM
vpasla1
Sep 17, 2016 07:24 PM
ROWDY621
Sep 30, 2015 03:20 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
Bielikb96
Sep 28, 2015 10:45 AM
