Will stock rims will rub with Eibach pro kit?
Will stock rims will rub with Eibach pro kit? what about when people are in the back? I got two subs and boxes in trunk too
what offset will not rub with eibach pro (on 17 inch or 18 inch rims)
Originally posted by Silverbulit40
no it won't rub
if you go 18s with the sub and people in the back then that requires you to roll the fenders in the rear because it most likely rub.
no it won't rub
Not on stock rims and tires. I rub with an eibach drop with 18x7.5 45 offset, 235/40/18. Do not try and fit 235 series tires with a system or you will have some real rubbing problems esp if you dont roll the fenders in. Go with a higher offset then 45 maybe 48+. WIth 225 tires u should be good. I still cant put my sytem in with my 235s and i rolled my fenders
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
